Reviews Gigabyte X570 Aorus Master Review
Discussion in 'Article Discussion' started by bit-tech, 15 Jul 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    Probably the best balanced premium X570 board in terms of features / looks / price...
    and as a bonus the chipset heatsink should be easy to replace with an aftermarket part.
  3. Broadwater06
    Broadwater06 Minimodder
    10 Apr 2016
    Not what you expect for £380 - 4 USB 2.0 ports.
  4. Mr_Mistoffelees
    26 Aug 2014
    Given that there are headers for 4 more USB 2 ports and plenty of USB 3.x provision, what is the problem?
  5. Broadwater06
    10 Apr 2016
    Didn't say there was a problem, just not what I expect to see in this day and age for not a cheap board.
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    It gets even worse when you go up in price, the £600 Asus ROG and £750 MSI Godlike only have 2x USB 2.0 ports. :eek: o_O
  7. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    Really not thrilled by the idea of a noise sensor (microphone) on the board - nothing to hide but no reason to add another security / privacy "feature".
    EEC memory support is what I'm actually looking for.
  8. azrael-
    azrael- I'm special...
    18 May 2008
    It's a motherboard and CPU feature. True, Ryzen support ECC memory, like most processors from AMD, but all that means nothing if the motherboard doesn't support it. To do that, not only does the UEFI need the necessary settings, but the motherboard needs the necessary traces from the CPU to the memory modules.
  9. azrael-
    18 May 2008
    Actually, most X570 boards apparently support it, as do a large amount of Xx70 and Bx50 boards. People often talk about the ASRock X470 Taichi as a good example.
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
Tags: Add Tags
