Reviews Gigabyte X570 Gaming X Review
Discussion in 'Article Discussion' started by bit-tech, 6 Aug 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    No USB 3.1 gen 2 front panel header, no interest.
  3. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Gigabyte using "Gaming X" as a nomenclature is turbo confusing - especially when the item in question is repeatedly compared to products from MSI... who use "Gaming X" for their GPU's.
    Also, still struggling to see the point in these "budget" X570 boards - barring PCI-E 4.0 (which is effectively useless), they are massively cut down on features compared to cheaper X470 options, but make no difference when running Zen 2 chips. Literally, who is buying this stuff??
    If it was a guaranteed extra 100Mhz with Precision Boost on X570 vs X470, I would get it...
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    I'm thinking more along the lines of X to symbolise a rejection buzzer sound rather than a number:naughty:
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Considering how severely cut down this one is? I'd say yes. It is as barebones as your typical £60 Biostar board, except it costs almost £200 cause mostly pointless PCIe 4.
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    It used to be £20 cheaper and i think you can still pick it up for around £180, not sure if that's down to the weaker pound or something else, not that £20 cheaper suddenly makes it good value mind. :)
  7. silk186
    silk186 Derp
    1 Dec 2014
    I would guess that a lot of people don't know that. I was asked to put a build together for a friend and looked at the X570 boards first but went with B450 due to budget. I wanted the PCIe 4.0 for future compatibility with new M.2 drives.
Tags: Add Tags
