Hardware Gigabyte X99M-Gaming 5 Review
Discussion in 'Article Discussion' started by Dogbert666, 2 Jan 2015.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. David
    7 Apr 2009
    Any word on if Gigabyte have fixed their EFI? I haven't used Haswell, but every gigabyte board I've tried/worked on has had a god-awful laggy EFI screen. I know they've tarted this one up, but is it more responsive than the older versions?
  3. Combatus
    16 Feb 2009
    Hi Spreadie. This one seemed fine. Bit laggy getting in but once you're there and you've switched to classic mode it's all good.
  4. David
    7 Apr 2009
    Good to know, thanks mate.
    Shame about the horrific price tag though. Mind you, even Asrock's X99 board isn't that far behind.
  5. Kastagir
    Kastagir What's a Dremel?
    1 Aug 2012
    2 x PS/2 Ports on a 2015 motherboard aimed at gamers?.... Know.. Your.. Audience.
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Just make sure you buy it before Gigabyte nerf the hell out of it like they have been doing with their other MoBo's when the bring out new revisions.
  7. TheMadDutchDude
    23 Aug 2013
    You may want to change that. :p
    Your images seem (to me) in the wrong order too. You're talking about stuff in images that are further up the page or non existent.
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Looks like a pretty nice board. It would be a better choice than evga since they didn't include m.2 at all...
    This board is so cheap it almost would make x99 affordable... if only ddr4 price would go back down.
    As far as Gigabyte uefi, I don't find it bad on my G1.Assasin.v2. Though, it newest version they removed that lame azz 3D bios thing so... it just goes straight to normal menu screen and is fairly snappy. Personally I do favor just simple screen with clear menu options. I don't need flashy graphic, mouse control, etc... Just need to enter to make setting change once in awhile not spend all day in there.
  9. TheMadDutchDude
    23 Aug 2013
    Oh, on a note of the UEFI, I didn't find the latest one that I used, on a Z87X-OC a year and a half ago, *that* bad once you get into the normal menu screens. You can make it default to that screen too so you avoid the slow 3D malarkey that they put in.
    The Z87X-OC however... well, that's a totally different story for another day. Atrociously bad in my experience of two.
Tags: Add Tags
