Reviews Gigabyte Z370N-WiFi Review
Discussion in 'Article Discussion' started by bit-tech, 29 Nov 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Neutronman
    Neutronman What's a Dremel?
    19 Aug 2016
    Good read. I looked through the documentation and see that MCE can be enabled in the bios on this motherboard. Does MCE work with non K model cpu's like the core i7 8700? Or just the K version? It would be fun to be able to enable this on an 8700 and run all cores at max turbo boost of 4.6ghz instead of 4.3ghz......
  3. TheMadDutchDude
    23 Aug 2013
    It's still good for NVMe, though... as far as I'm aware.
  4. aikidoka25
    aikidoka25 What's a Dremel?
    14 Dec 2017
    Is the wifi card replaceable? I have to change it to make it compatible with the os, whatever my reason is :)
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Nope, not physically removable.
  6. aikidoka25
    14 Dec 2017
    Thanks for the reply Andfield, I know it is in the protective metal shied, wondering if I removed it (there are 2 screws below), inside it, is it a removable card or soldered?
Tags: Add Tags
