Gigi's2nd.Project:Hard_core-Cold_steel-Case_mod [G5] 1830@2650w/ZalmanWatercooling
Discussion in 'Project Logs' started by gigik, 7 Oct 2004.
  1. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    This is coming along nicely! Bit much with the bolts for my taste, but I can see how it fits with the industrial theme. Love your steel.
  2. gigik
    gigik What's a Dremel?
    18 Aug 2004
    neew stuff
    @ ReFredzRate : it was a very mad-mod, not enough money to buy dfi lan party mobo so i take an old mb and PAINT IT ALL :hehe: :hehe: :hehe: ,
    alone chasis have about 2kg...
    with hard-core-steel-modit weigrts about 10kg :)
    painting with clear coat
    wheels :)
    [​IMG][​IMG]
    [​IMG][​IMG]
    i am starting testing airflow :baby:
    thnx4supp :D
  3. henson0115
    henson0115 Banned
    16 Apr 2004
    for better airflow wouldn't you benefit from another fan inbertween the fan on the bottome of the front and the cd drives, correct meif i'm wrong though
  4. gigik
    18 Aug 2004
    2*80mm on the ramp (to reduce noise)
    mad-mod-board
    [​IMG][​IMG]
    new power suplly has tooh on the other side :) lets mod
    as ussually in my mods i replace one 80mm fan@12V with 2*80mm@5V
    to reduce noise but it stay good cooled
    srry about quality, 3supports fans for cpu :) 2500+@3200++= 90W of heat...
    if i had a big foot wheels........
    aplle original from Aplle :)
    lleds, 5mm, red, 3000mCda
    4 on which side
    from outside
    stay tuned :))
  5. Gangsta
    Gangsta Banned
    3 Jul 2004
    wow man! awesome mod :rock: i wish i had time to do a poject log (damn GCSE exams :grr: ) anywayz :D
    :dremel: !!!!!!!!!!MOD ON!!!!!!!!!!!! :dremel:
  6. Bloody_Sorcerer
    Bloody_Sorcerer What's a Dremel?
    16 Nov 2004
    nice use of steel! bravo, looks alot like a Lian Li, except better :)
    How did you manage to paint the mobo without covering necissary contacts (like the little contacts inside the PCI slots, pins-receptacles in the socket, etc)?!
  7. estek
    estek What's a Dremel?
    21 Jul 2004
    Great mod, looks awesome. ... Hey Gigi how did you bend the metal ?? did you use any special tools or just hammer and other regular stuff ...
    Great job .. would you be paiting it ?? what color ?
  8. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Nice mod. That looks really factory like. Just put a little teeny weeny bit of rust in the corners or somewhere. That was just an idea so if you don't like it, ignore it.
    Keep modding
  9. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    ROFL - quality work man - did anybody ever tell you that you're crazy?
  10. Bazman
    Bazman What's a Dremel?
    13 Sep 2004
    Great mod! I can't wait to see this finished, and see how the lights interact with that perforated steel. Should be a great little light show going on!!!! :rock:
  11. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    I don't think you ever need to worry about over heating. That case is one giant heat sink.
    Bending steel can be a pain. Did you do it by hand or use a pan-break or something?
    Looks sweet. Keep up the updates
  12. Lost.Soul
    Lost.Soul What's a Dremel?
    26 Oct 2004
    Nice mod man, the mobo is funky :D
    *native speak* konecne se tu obevil nakej cech :lol: sem myslel ze sem tady jedinej.. :rolleyes: Jinak peknej mod, jenom misto tech ledek bych tam dal katodu... :naughty: */native speak*
  13. gigik
    18 Aug 2004
    2Bloody_Sorcerer: as i said before, that motherboard was already death
    2estek: for bending i use ony strong of my arms :) and maybe hammer :) :) ,color ...probably no color, only clear paint
    2Tulatin: my freinds tell me it every day :D
    2Lost.Soul: yea, yea, finally i will use cathode (plus some leds) :)
    front
    back
    top
    cool
    detail
    power switch - behind the aplle :)
    inside
    i found a old VU-metr, so i used it :) 2x5LED
    power from usb (my first case)
  14. white modder
    white modder What's a Dremel?
    19 Sep 2003
    looking very good, awesome
    maybe you can light up the applelogo with a diffused blue/white led?
  15. k3rnel
    k3rnel What's a Dremel?
    25 Nov 2004
    I like the screws all over. Gives a really cool industrial feel. :rock:
  16. roachm
    roachm What's a Dremel?
    16 Nov 2004
    This mod is giving me inspiration to do something similar, I really like the way its turning out. Very good job man :).
    One sugestion, although the whole 'mesh' type stuff you used is a really good way to improve all around airflow, you should cut out where the fans are and use standard fan grills, alot less restrictive.
  17. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    its like lian lai meets apple, koolz, keep up te good work
  18. Herbicide
    Herbicide Lurktacular
    27 May 2004
    x86's revenge?
    Nice heavy industrial feel. What's the paintjob going to be, or are you going to leave it as it is, perhaps just a going over with clear coat?
    - H.
  19. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    nice modding, if that case doesn't get great airflow i don't know what will.
  20. gigik
    18 Aug 2004
    i tryied to hide cables
    my dear components (i am student and i have to work for one month to make money for them :)
    all ok
    default fan on graphic card
    after my tuning
    i have tryied what can i get from grph. card...fans to the max :)
    2x 80m@12V + 92mm@12V (3200ot) very noisy....overclocekd from 400/600 to 540/690 ( for the present there are no pasives on the memores, but after that...)
    for the present overclocking results : barton2500+@3800+(1853@ 2475mhz at default voltage) fsb:225 x11, 2x256MB dual ddr 400@ 450mhz, Ati R9600Pro 400/600@ 535/680mhz
    i did not tweaking up the voltage so after i will install active cooling to north bridge and pasives on graphic card memories... :hehe:
