Hardware Gioteck EX-05 review
Discussion in 'Article Discussion' started by brumgrunt, 19 Dec 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. rollo
    rollo Modder
    16 May 2008
    Theres better headsets for little cash more
    if your budget is even £35 theres better headsets
    Below £35 your better off with some low end logitech headset.
  3. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    As that is your opinion (although most likely an agreed upon one) you may want to give a few examples...
  4. alastor
    alastor Minimodder
    6 Sep 2004
    I've had the xbox version of these for nearly a year now and the sound has improved significantly over that time. A bit of burn in does wonders for the bottom end. The headband is still uncomfortable after a while though :(
Tags: Add Tags
