Modding Girly PC!
Discussion in 'Modding' started by voodoo2k4, 30 Aug 2004.
  1. voodoo2k4
    voodoo2k4 Ghetto Modder
    21 Apr 2004
    Luckily i have a girlfriend who is put off by things geeky, and refers to my blue,black n plexi box as "quite kool".
    Now as a present for her going to uni i somehow agreed to make her a fully custom PC which I have no problem doing. Just that there needs to be pink in the equation apparently. Im thinking of going with a gloss white case, keyboard, mouse n speakers and then interior lights and detail lights and LED's in pink to set it off. One problem though, you cant buy (quite rightly!) pink cathodes and LED's anywhere it seems!
    Help suggestions? I was thinking about painting (with the appropriate translucent paint) some clear white LEDs (can you get them?) in pink.
    deano.
  2. dmcm01
    dmcm01 Banned
    15 Aug 2004
    why dont you get a red CCRT and a white CCRT? unless it doesnt work like that?!
  3. Kingskin
    Kingskin What's a Dremel?
    17 Aug 2004
    afaik you cant mix light and get the same results as if you were mixing paint - however im sure you could esily make some LED/cathode filters for white versions out of lighting filter plastic, or like you suggest, translucent paint
  4. bmh.01
    bmh.01 What's a Dremel?
    7 Mar 2002
    Red CCFLs are mostly pinkish in colour, i'm yet to find one thats totally red (came close with sunbeam ones).
  5. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
  6. fg0d
    fg0d Banned
    18 Jan 2004
    What you want to do is, get a white cathode, and buy some of that seran rap sorta paper, its clear and comes it colors. Buy it from paper stores or craft shops and use light glue to glue it. Im sure Ive seen an article on this, Ive tried it and my cathode is a nice looking purple.
    here is the article: http://www.gruntville.com/howtos/ccflwrap/
  7. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    i can see fire what about the heat :duh:
  8. -blackout-
    -blackout- What's a Dremel?
    1 Jun 2004
    cold cathodes don´t produce heat :D
  9. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    I made my wife's shuttle PC totaly pink.
    The monitor, keyboard, mouse, speakers, even the ATI remote.
    You can get a color of krylon Fusion called "Fairytale pink"
    But clearcoat the paint!
    I have not images of my wife's PC, as the paint didn't last long under use.
    I have to repaint the keyboard and mouse now.
    I used some white cold cathodes, LEDs, and some "Red' ones that look very pink.
  10. voodoo2k4
    21 Apr 2004
    just spoke to her and "yes it has to be pink!" so bang goes my iPod idea! What on earth colour lighting can I use with it? She says yellow i reckon thats too much! Btw where can I find a stealth drive FAQ as I want blank drive face plates that you just press in one corner to open! :)
    deano.
  11. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Ebay has pink LEDs, the Honk Kong seller that ships worldwide.
  12. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    bit-tech has the answer to everything :p
  13. Ben '71 1200
    Ben '71 1200 What's a Dremel?
    16 Aug 2004
    Don't think Kong would like being honked :D
    That seller is very good by the way, I got 50 UV LEDs for £5 from there.
  14. Hazer
    14 Apr 2003
    Lol. :hehe: :hehe: :hehe:
