Linux Giving linux a try
Discussion in 'Software' started by Pballer98c, 1 Jul 2005.
  1. Pballer98c
    Pballer98c Minimodder
    2 Jan 2005
    i have decided to give linux a try, as i do not want to purchase a copy of windows. so here is the deal, i am a gamer but i am also a college student so, i MUST be able to use Word, Exel, and Powerpoint (WINE??) plus play my games (hl2, bf2, ultima online) (cedega??). I also do some website design/development (GIMP/GIMPShop??) I am totally new to linux, and i also plan to store a huge dvd library on multiple hard drives. which linux is reccommened, and can you share any tips? my current system is an athlon xp-m 2500, asus A7N8X-E, 1gb ddr 400 ulta ram, 120gb WD hdd, 300gb seagate hdd (dvd's), and a g-force fx 5500 OC graphics card. thanks
  2. Go4t
    Go4t i
    13 Dec 2003
    word excel and powerpoint - you can just use openoffice which does just about all the same things and can save as office formats
    cedega works just fine (most of the time) for hl2 and probably fine for ultima but i dont know if they have added the bf2 support yet
    no problems with multiple hard drives on any distro, only thing is you might want to make them a writeable format (fat32 or a *nix format such as ext3)
    the gimp is pretty powerfull but its still not photoshop but photoshop and the office programs work with crossover office which is another modified version of wine like cedega
    as for a distro i would reccommend gentoo just so you learn how it works but it gets to be a pain in the ass so you might want to try something like ubuntu or suse
  3. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    Gentoo for someone trying Linux is mad! Go for Ubuntu or the like. For multiple hard drives the filesystem doesnt split off like in windows you wont have C:, D: e.t.c just / and /blah could be on a totaly different drive and /blah/blah on another.
  4. Go4t
    Go4t i
    13 Dec 2003
    oh bah gentoo for a first time isnt mad its pretty easy if you read the handbook and browse the forums
  5. trigger
    trigger Procrastinator
    22 Mar 2004
    Maybe try Gentoo if you are brave and have a spare day or two (!). I'd really advise Ubuntu (or Debian proper if you don't need the ease of Ubuntu), or Mandrake/Mandriva.
    All your hardware should be OK, but make sure you get the nvidia drivers if you want to game (rather than the default builtin ones).
  6. Pballer98c
    2 Jan 2005
    i will be giving Ubuntu a try (might try gentoo after a few weeks of playing with ubuntu). Downloading the live cd and install cd iso files as we speak... i also saved some the guides from http://www.tldp.org/guides.html.... are there any other simple guides availible? thanks
  7. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Check out openoffice.org for your ms office needs, GIMP for graphcis and WINE/cedega for any windows programs you still need to run.
  8. Pballer98c
    2 Jan 2005
    thanks, however im having some trouble running the live cd now. i set my first boot to cd, 2nd boot is still hdd 0, yet it is still booting into windows. gunna burn a new cd and see if that helps. thanks
  9. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
  10. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I don't think you stupid or nothing. But are you burning the .iso onto the disk. or are you just making a data disk with the .iso in it?
    becouse doing the last one will get you know where
  11. Pballer98c
    2 Jan 2005
    na, i just had a few bad cd's. tried out the live cd and was amazed. So, I just installed it (about 10min ago) and now im making my first post from a linux machine :). So far, it seems great, just need to download all the programs for my games ;). thanks for all the help
  12. woodshop
    woodshop UnSeenly
    14 Oct 2003
    HAHA don't thank use yet that was really the easy part.. its getting it all working and you happy with it that'll be hard.. HEH but it's not all that bad for a free OS though is it not?
  13. Pballer98c
    2 Jan 2005
    no, very smooth, comes with lots of free software, eye appealling. but you are right, i have already run into my first problem. It will not see my 2nd seagate 300gb hard drive. i was going to install it using discwizard but thats a windows only program. how should i go about installing it?
    also cant figure out how to install cedega or wine :-X o well... more reading in the future it seems
    thanks
  14. BBurger
    7 Apr 2005
    If you're on IRC, the #ubuntu channel on freenode can be very helpful. Likewise the Ubuntu Forums off the official website.
    Mounting HDDs isn't difficult, but I don't know how to do it myself...
    Wine is in Ubuntu's repositories, so you can install it via Synaptic. I've seen it there, I know ppl have gotten Wine working in Ubuntu, but again, I haven't done it myself...
  15. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    See, Gentoo might be slightly tricky to install (Well, it's not really if you read the very good install manuals...) but installing things on Gentoo is just stupidly silly... :D
    Code:
    #emerge appname
    Normally does the trick :D
    Sam
