News GlobalFoundries prepares Tri-Gate competitor
Discussion in 'Article Discussion' started by arcticstoat, 12 Jul 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    " How small can we make silicon transistors before they become unmanageable?"
    Well, that's an easy one to answer - the lower bound is going to be the size of silicon atoms themselves :)
  3. Jezcentral
    Jezcentral Minimodder
    7 Sep 2009
    So, are we on course for Moore's Law to break down in 2017?
  4. Xir
    Xir Modder
    26 Apr 2006
    wouldn't happen to have mentioned something like "Triple-Spacer" or "Finfet" now would he?
  5. WildThing
    WildThing Minimodder
    26 Jul 2007
    Nice to see Intel's competition doing something, and thanks Paul for the gate-first vs gate-last explanation, been wanting to read up on that for a while now. Cheers.
  6. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    Last I heard the issues are around 8-10nm and that is about where any current and most theoretical manufacturing techniques are unable to produce a viable transister. So we have at least another 4-6 years before we are at neeing a major "break through" to keep advancing transister size.
    The gist I got from the article is basically that "Hi, we are 1-2 years behind Intel, but don't worry, that works for us!"
    Most of the time I hear things about using "backwards" technology because you haven't innovated or there is a defect, companies always spin it as a "design feature" or "it gives us X benifit". So 10-20% space savings compared to gate last at 28nm, I doubt that, or if true it is because of your manufacturing technique and the way you are laying out the chips. That or it may be true, but yields are significantly lower for you to change or too much time redesigning the process. Or it may also be true, but transistor performance is lower.
    Since Intel and TSMC are doing gate last I don't think they decided to do that for no reason.
    l3v1ck likes this.
  7. Guest-16
    Guest-16 Guest
    Thanks for the write-up Paul!
  8. John_T
    John_T Minimodder
    3 Aug 2009
    I love reading all this kind of stuff, even though I'll admit to only understanding about half of it!
    I am amazed by the constant shrinking process, even more so when I look back at some of the older PC's I've had over the years. The original Pentium was, I believe, based on an 800nm technology - so to now have 28nm, to be preparing 20nm - and to be talking about 14nm transistors being well underway, I do think it's all pretty amazing.
    Just roll out a tape measure to 800mm, then roll it back down to 20mm & 14mm for a visual comparison of scale. It's astonishing what they have been able to achieve in such a short space of time really...
    l3v1ck likes this.
  9. ssj12
    ssj12 Minimodder
    12 Sep 2007
    Why is it I suspect they saw Intel's tech announcement and said "oh crap, get to the drawing board ASAP!?"
  10. Guest-16
    Guest-16 Guest
    FinFETs (branded 3D transistors) were originally developed by IBM actually iirc - who GloFo is in a co-operative development relationship.
    It was on Ee times I think.
    http://en.wikipedia.org/wiki/Multigate_device
  11. Xir
    Xir Modder
    26 Apr 2006
    Yup. The AMD-IBM alliance (direct follower of the AMD-Motorola alliance) :D
  12. stonedsurd
    11 Mar 2009
    That's more along the lines of what I'd like to see around here. Great article and well done Bit!
    PS: Paul, do have an aunt named Holly?
  13. ssj12
    ssj12 Minimodder
    12 Sep 2007
    That sounds like a horrid alliance. Thank god I have my Droid X2.
  14. Xir
    Xir Modder
    26 Apr 2006
    The AMD-Motorola Alliance gave you copper-interconnects which led to the break of the 1Ghz barrier.
    (while Intel still said...naah Aluminum will do just fine)
  15. saneblane
    saneblane What's a Dremel?
    19 Jul 2011
    intel may be ahead in lithography but IBM is always ahead in R&D, that company just knows how to conduct themselves. and what they develop is the research they do benefit so many companies and people. amd then their is AMD, the company with the most pioneering chip designs, with the bulldozer arch, we don't even know how to count the cores. this is what happens when competitions is tough, people innovate
Tags: Add Tags
