Modding Glowing Mouse
Discussion in 'Modding' started by :: Phat ::, 24 Jun 2002.
  1. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    If you've got the ultimate glowing computer one of these is a must! cheap enough too, so you wont have to buy a normal one and some EL wire.
    Click MEH!
  2. x24
    x24 What's a Dremel?
    9 May 2002
    Why buy one when you can make one? That's basically an additionally lighted mouse mod and Japala's fire wheel mouse mod with a blue LED.
  3. :: Phat ::
    7 Jun 2002
    yeah but by the time you buy a cheap optical mouse with a clear bit, maybe some EL string a few bl00 Led's etc... is it really worth it?:blah:
  4. Ubermich
    Ubermich He did it!
    21 Jun 2002
    YES!!! DIY! DIY! DIY! Ok, enough ranting (gotta lay off the crack, I know). Now, if the colors swirled around on that mouse... *Idea* If you had, say, 3 sets of 3 or 4 different coloured LEDs, and you had them go on and off (within the group). Voila! swirling lights!
    Ok, putting down the crack now.
    If someone was completely against diy, that would be the way to go.
  5. :: Phat ::
    7 Jun 2002
    I'm all for DIY! This just seems as a nice easy solution, play with it for a few months then MOD! Maybe swirling lights.... A strobe.... a laser.... smoke machine.... foam machine.... popcorn cannon....
    Ok Ok Ok!! Take your crack back!
    How's about a watercooled mouse to keep your hand chilled? :idea:
  6. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Even better! Liquid nitrogen-cooled!! :eeek:
    What if you did have a little fogger? Nevermind, crack is put away. :D
  7. :: Phat ::
    7 Jun 2002
    Hmmmm liquid nitrogen...
    Go to doctor with mouse stuck to tongue.
    Doc - "So what happened here sir?"
    - "Wehhul I dwopped thome dwink on mayh moousthe and twied tho lich it thup"
    You could always throw it at burglars and do the whole TII thing.... "Asta La Vista...... bebeh!"
  8. hexa-db
    hexa-db What's a Dremel?
    2 Apr 2002
    I've seen an article on mounting a small fan in a mouse to prevent sweaty palms. Looks like quite a nice idea.
    As for doing it yourself - how do you get the led to make the wheel glow? It looks a bit too opaque to glow...
  9. Ubermich
    Ubermich He did it!
    21 Jun 2002
    That's the only difference between this and other mice. This one has a translucent wheel. I'm thinking about how that would be possible to do yourself...
  10. x24
    9 May 2002
  11. :: Phat ::
    7 Jun 2002
    X24 surely isn't it Ren and Stimpy not Stinky???:cries:
  12. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Most excelent! If my logitech were still alive... :sigh:
  13. x24
    9 May 2002
    Stinky is the one who sang the Happy happy joy joy song that Stimpy loves so much. (check the link for the lyrics and some audio). Nice to see people who knew Ren & Stimpy.
  14. G8way
    G8way What's a Dremel?
    24 Mar 2002
    put tiny fish or something in a sealed off area of the mouse, kinda like those fish shoes :p
  15. brutal
    brutal What's a Dremel?
    7 Nov 2001
    figure out a way to wire super flux leds into your mouse and it will look like that :)
  16. cderalow
    cderalow bondage master!
    23 Jan 2002
    i'd go out and buy the one IBM makes before i bought that one.... looks naff and crappy
  17. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Take the knight rider LED setup and make that so it speeds up/slows down depending on how close the mouse is to it!
    Then instal a flux capacitor and throw the mouse across the room at another computer and watch it dissapear, leaving nothing but a line of flames.
  18. KypD
    KypD What's a Dremel?
    8 May 2002
  19. Ubermich
    Ubermich He did it!
    21 Jun 2002
  20. :: Phat ::
    7 Jun 2002
    Cool idea, can you throw your mouse "At Eighty Eight Miles Per Hour!!!"?? hmm can you?
