Modding Glowpad - Etched Letters and Logo - What do you think?
Discussion in 'Modding' started by Skylined, 7 Jul 2004.
  1. Skylined
    Skylined Minimodder
    3 May 2003
    I'm going to be able to use a router to make etched letters and logo.
    Skylined is my nickname, unfortunately it was already taken here, that's why here I'm Herdkilling :)
    The mousepad is marked in red.
    The logo will be etched too, and it will be blue as well as the letters.
    Do you like it?
    Do you have a better idea?
    Anything I should be aware of?
  2. Twunka
    Twunka What's a Dremel?
    12 Feb 2004
    hows about you flip it upside down and do skylined diaginally across the bottom of it with the logo done at a different depth so it looks different with 2 leds in either corner
  3. Skylined
    Skylined Minimodder
    3 May 2003
    I don't really get your idea.
    Can you draw what you're saying?
  4. Twunka
    12 Feb 2004
    Code:
    [CENTER]___________
    S             x|
      K             |
        Y           |
          L          |
            I        |
             N       |
               E     |
    x_______D__|[/CENTER]
    kinda like that if u get what i mean with the logo behind the letters "skylined" then just use frosting spray on the back and optical mice wont have a problem with it.
    edit just imagine the lines all line up on the side
  5. henson0115
    henson0115 Banned
    16 Apr 2004
    what has the ant got to do wwhith sky lined?? and if you did the lettering smaller by a touch you could all so use a diferent font
  6. Skylined
    Skylined Minimodder
    3 May 2003
  7. Skylined
    Skylined Minimodder
    3 May 2003
  8. keir
    keir S p i t F i r e
    5 Oct 2003
    llatest
    pics dont work :duh:
  9. Skylined
    Skylined Minimodder
    3 May 2003
    They work for me...
    Have you copy pasted that address in the address bar?
  10. keir
    5 Oct 2003
    yes, unless this is ur design.
  11. Skylined
    Skylined Minimodder
    3 May 2003
