Other Glue mould, how to make the glue not stick.
Discussion in 'General' started by Matticus, 3 Dec 2008.
  1. Matticus
    Matticus ...
    23 Feb 2008
    Today I was at college, and this happened
    Oops! :hehe:
    So I want to make some sort of new cover for it. My initial thought was a lego brick or backspace key, and I will do one of those if the glue thing doesn't work.
    Basically I want to make some sort of mould so I can cover the usb stick in glue. I have a hot glue gun to do it in but I just don't know what I can cover the mould in to stop the glue sticking.
    Any ideas, or any better ideas for what I put it in...
  2. *Alex*
    *Alex* What's a Dremel?
    23 Mar 2008
    maybe try vasaline
  3. dom_
    dom_ --->
    4 Jan 2004
    Will hot glue work well? Not sure if you can squeeze enough glue out before it starts to set elsewhere.
    Anyway, to the original question, vaseline?
    edit:Beaten!
  4. Matticus
    Matticus ...
    23 Feb 2008
    Genius, why didn't I think of that.
  5. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    It'll melt from the heat of the glue and go runny and come off.
    Clingfilm works well with most glues, but I don't know about the hot glue.
    Otherwise use basic PVA glue (may take a while to set though).
    Some sort of plastic you really need, or cold metal / glass.
  6. Veles
    Veles DUR HUR
    18 Nov 2005
    Yeah vaseline should work, works with many other sticky things
    err, that came out wrong
  7. capnPedro
    11 Apr 2007
    Tinfoil. Sand it off afterwards. Nice frosted look.
  8. Krikkit
    21 Jan 2003
    Get a sandwich bag, put it in that, then dip it into a vat of something like PVA. Hot glue might damage it.
  9. Firehed
    15 Feb 2004
    Tinfoil on an electrical circuit?
    I'd strongly suggest disregarding this advice.
    Any sort of semi-solid should work well enough if you're going to try making the mold from hot glue. Vaseline, butter, Crisco (vegetable shortening)... anything of that consistency should work well enough, especially if you have a low-temp hot glue gun.
  10. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    2 part epoxy, i would love to see you try and get that off.
