whats the best glue to use when gluing plexi glass to wood? because im guessing that wood glue wont be any good for it. its gunna go like this: wood ================ plexi --------------------- wood ================ if i have to i'll probably also put through wooden pegs for strength, even though it'll probably make dark spots where the light shines through the plexi So anyone got any glue reccomendations/ gluing methods?
go with epoxy and clamp the hell out of it to get it nice and tight, i wouldent trust the wood glue on the plastic
ok so epoxy it is then, what about putting pegs through it? do you think they'll be necessary? will the epoxy be pretty strong?
im guessing it'll be strong enough, im making a case, and i just dont want it to fall apart when I go to pick it up. VERY cool table there btw
the pegs are not nessisary the epoxy will make it more than storng enough for even the most harsh conditions after it is all glued and dried i would run the peice around a router and just shave of like 1/32 to get a perfect fit
