what's the best to glue acrylic? - super glue -solvent but which? For the nail? -Chloroform -Silicone -... thanks
The best is to use a solvent cement specifically designed for polycarbonate/acrylic; I would not suggest using nail polish remover or acetone.
If you want to join flat to flat, then use Acrylic cement (used via capilary action) or end to end or end to face, then you'll want Tensol Cement
I don't remember the name of the one I use, but its a Plastic Cement type glue, not one that comes in 2 parts though but seems to glue all the stuff I need, I'll check the name when I get home if you want? Its a well known name but I can't for the life of me think what it is!
ok so for you acrylic cement is the best glue. ok thanks a lot but i'm french and i don't kown the french name of "acrylic cement"... nobody know the name of this solvent in french??
Well I'm using this model glue, seems to work pretty well for what I've used it for, sorry not sure what it is in French... Basically contact adhesives are pretty strong so long as you get one that will work with your type of plastic
Model cement is not the right glue for acrylic; you should be using a water-thin solvent cement such as weld-on #5 or Polycarbonate Cement SC-325
@devilhacker look out for acrifix....it is the right cement for joining acrylics and i think it should be available in Belgium (normally only ground shipping is allowed, thats also the reason why its so hard to find weldon etc. here in europe)
I find glueing large flat areas of transparent acrylic is difficult to not get air bubbles though. They look nasty. Tensol Cement also Cheesecake
Hmm well I've not had any problems with the model cement, why should you not use it?... Incidentally I was using some Rapid Mitre Fix the other day, seems to work well and sticks fast! Its a 2 part thing, you put the glue one side, spray the other and when you put them together it sticks strong, might be worth a try... By the way, what is Weld on #3 or Weld on #5, where would you get it because no shops around here have heard of that?
Weld-on #5 is a solvent cement that partially dissolves the material to provide a better joint; the model glues just sticks them together, and often results in a off-color film between the parts.
Ah fair enough, I suppose it depends if you are using clear acrylic and how strong you want the bond to be, I'll look out for some solvent cement!
It is manufactured by a company called IPS. Link to their website http://www.ipscorp.com/ I don't know about getting it in UK but it really works well. John
Just go here for some information. there is much info going on here that will harm you rproject more than help it. http://www.ipscorp.com/industrial/acrylics.html if you have a chemical supply store near you. you can get methyl Chloride. it is the primary ingrediant in acrylic glue.
The "proper" acrylic adhesives leave a clear and very thin glue line; poxy resin is OK if you need a lot of gap filling. I've tried making my own cement from perspex bits dissolved in methyl methacrylate, but it's nowhere near as good as the Tensol solvent cement.
