Scratch Build – Complete ⭐ Goa´uld Al´Kesh [scratch build]
Discussion in 'Project Logs' started by ronny78, 9 Oct 2017.
  1. zak
    zak Build Clean people, build clean
    18 Apr 2018
    OMG you use MIFFLIN TOO??? I love them, its the only acrylic I buy now, I discovered them a few months ago, and there stuff is so good and in so many colors!
  2. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Hello,
    The first thing I noticed in this photo was that something was wrong on the IO-Shield.
    I did not notice the tinkering, although I had marked lines was the lettering good 5mm wrong.
    I was maybe a little annoyed because the font for the plotter was too small.
    okay fixed
    Now it was up to the CPU cooler.
    Unfortunately, this time nothing fit.
    The socket screw was in the way, so I had to adjust that a bit.
    To use the M2 SSD, I also had to shorten the backplate by a few Millimeters.
    From the pyramid, I have now cut out the window.
    It was rather modest, so I had to file and grind a lot afterwards.
    for fear of breaking anything I had to examine the glass for scratches and damage.
    But as far as I can see nothing is broken.
    Now it went to the gas pressure damper.
    For this I cut two brackets made of aluminum
    then have the holes drilled and fixed the whole with the fiber-reinforced polyester putty.
    Now everything was embedded again with GRP .
    to test something I then decided for 2x40N gas spring.
    That means that the lid and the Al'kesh weigh 8kg each time.
    Since the whole upper part was still a bit unstable for me, I spent most of the last week with it
    to reinforce the entire interior and then smooth spatula. That was a **** I tell you because everything is round.
    The gas pressure damper I painted gold, the tube itself is then gold chrome foils, matching the tubes and Fittings.
    Soooo what can not be missing in an Alkesh?
    A Goaúld bomb for self-destruction :stupid:
    The best way to do that is by deep-drawing so first of all a mold had to be made.
    When digging in my wood waste box, I found these two sections quite well.
    So I put these on a threaded rod and, like a glassblower, carefully guided it to the stand grinder.
    then the same on the lower part
    Then I put both together. With a little sanding dust and wood glue you can easily stir a putty together.
    The bomb can still wait, for the thermoforming box is currently no place.
    On to the interior, the flair of a spaceship should reflect itself again inside.
    First, the view must disappear to the PSU.
    With a little cardboard I could create a template to put two walls of Plexiglas.
    Just as big as the PSU fits through and I can plug in the cables behind it.
    They then only dress up the visible area so that I can lay cables under the walls
    short test, is still working
    in front of the PSU comes a hinged door which I bent a short hand from Plexiglas.
    This then closes flush with the Alkesh.
    Since I am very reluctant to start the circular saw during the week, I have cut the pillars for the interior at the weekend.
    First cut 8mm Plexiglas in 1cm strips.
    then fastened with tape and put a 3mm deep cut every 15mm.
    yes i like it, to be continued
    In the mainboard tray I have now the last holes for pipes, res, USB3.0 and HDMI cable set.
    And today I started to cut the first pillars.
    Okay, thank you until next time.​
  3. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Yes, of course. It's just better for perfect work. Costs a little more. I have the extruded acrylic just because the waste in the hardware store cost only 1 euro. Is good for practicing or if later painted.
  4. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Sooo let's go on.
    There will be a lot to report after this weekend :cool:
    Where do I start?
    I pretty much worked on all areas in parallel, but sorted the images by topic to keep things more manageable.
    The drives were finally fastened.
    Since the fiber putty is hard after 5min I held each drive individually in position and lubricated from the inside the putty with finger on it.
    I actually wanted to be able to remove it and glue it at the end, but it was not necessary. After the second fiber putty operation, they held up very well
    Then I came up with a brilliant idea.
    For the drive I have cut 4 rounds of 1cm Plexiglas
    the edges thereafter roughly chamfered by the router and not ground on purpose but only slightly polished.
    The effect fits very well when all lights up
    after that I prepared the original light guide plate and the new one for gluing
    and glued to the Acrifix R192. Of course this worked right away (almost where it does not matter :wall: )
    The result, unprocessed, perfect. No bubbles no cracks. I do not expect anything more. :heul:
    Now the impression that I imagined :banana:
    Then I started yesterday to put the holes for the LEDs and glue these.
    3mm blue concave
    Part 2. The bomb
    Now I could finally dig out the thermoforming box and deep pull the bomb.
    If someone wants more details just let me know. ;)
    after I cut out the bomb with scissors and sanded it reasonably straight.
    Have I set a clean cut to the desired height with the Proxxon tool.
    Coooooool
    then I cut a ring on which I can then stick a LED stripe
    Now I painted both from the inside without a primer black, because as I said, the green does not fit into the concept.
    I've got 4-5 photos of the bomb or Al'kesh control panel here and only one of them is green. The others are all black.
    Also, each has different symbols.
    Which brings me to the next point.
    I could not find a direct font for Goa'uld writing.
    There are either only the gate symbols or it is referred to one of the many ancient Egyptian scriptures.
    None of them would be eligible for the bomb.
    I had then first made a few decals with the ancient script which I was also allowed to manually trace but that did not look good.
    So I traced the font from the photo of the last post and used it.
    Luckily, I could see just 10 icons to assign them 10 LEDs.
    Part 3. The holder second try
    The basic idea was already in my head for a while, but I still lacked the final attachment to the Alkesh itself.
    As usual, "hit it and get started" I've just built it and I do not think it's that bad.
    1. Create an ellipse and half close it to the circle.
    This then cut out of 8mm extruded Plexiglas
    Then with the router all edges chamfered to 4mm.
    Now I cut a 4cm Plexiglas rod at 20 degrees.
    the whole is then glued to the base plate
    Now the support surface for the Alkesh.
    Also cut here 8mm extruded Plexiglas and bevelled all edges to 2mm.
    After that I started to bend both sides by 25 degrees each 4cm from the center.
    Great the photo forget crap!
    4cm from the outside I bent then by 65 degrees.
    Thus I have three points that I can push into the Alkesh and under the radiators still enough space for the ball valves and sufficient supply and exhaust air
    Part 4. The pillars
    Just the 8mm slit Plexiglas strip was not enough for me so I cut out of 3mm Plexiglas also 8mm strips and have these all provided with Slots.
    so in style
    Now I've cut all the pillars exactly to length
    and then stuck the 3mm Plexiglas in the offset
    Now I began to prime and fill all the pillars.
    until I was satisfied with the surface.
    Now I stuck all pillars with foil. Similar to the sarcophagus.
    Then everything again primed
    and painted several times in Gold.
    Last but not least part 5. The Alkesh
    At the Alkesh I had to put under the res one more recess so I can put the pump directly under him.
    Then I positioned the IO-Shield from below behind the radiators
    Although I actually wanted to do without it, I smoothed the interior once again
    everything primed
    and then closed the last little holes to waterproof the whole case
    The motherboard tray I have already provided with a 1K Alugrundierung and a few layers of primer
    So far, so good, nice to finally see a little bit of color :banana:​
    Dot_Kappa and _Prometheus_ like this.
  5. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    Tek'ma'tek Tauri!? What did you call me!? JK the internet says: Friends well met. We come in peace. Earth, the people of Earth. Whatever that means
  6. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Tek`ma`te Master!
    Tek´ma´tek and Tek´ma´te are respectful greetings or I come in peace.
    Tauri is the name for man/People/human in goa´uld language.
    Also " I come in peace man" or "Greetings human"
    I am not Goa´uld I am Tokra :rock:
    So that was a short week but it went forward.
    The base plate of the bracket has been polished.
    The acrylic glass rod I have now glued to the base plate.
    Now I put the holes for the holder in the Alkesh
    I then filled the cavity (between the attached trapezoid of the rads and the actual Alkesh bottom) with glass fiber spatula
    fits
    Now I've polished all edges of the bracket
    and here is an impression of the holder.
    I still have to glue the overlay to the pipe. Still coming.
    then I began to paint the Alkesh and prepare for it.
    First only primer.
    The waves on the top were filled two to three times with the polyester spatula
    then back primer and a tin of spray filler.
    Now everything looks different and feels much better
    Now I sanded the whole wet with 400 and had to make only a few corrections.
    The lid here is exactly the same.
    Here you can see quite well the looped points of the first operation and how the areas in between all filled with polyester spatula.
    The current status.
    To no new waves or bumps purely to grind through too much grinding I went over only with paper 600 and have primed everything again.
    I will definitely repeat the whole thing 2-4 times until I am satisfied.
    Well, we'll see.
    Short week and then there is plenty of time to keep working:cool:
  7. Gress
    Gress What's a Dremel?
    10 Mar 2018
    Marvelous work, i particularly valued your ability to use scraps or common (apparently unthinkable) objects to make parts of only the molds for your mod. Your quite a genius :D
    Since i loved the stargate movie and stargate SG-1 saga, i probably appreciate even more your work!
  8. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Never watched SG but dosn't lessen the appreciation i have for the skills you have on show. I miss doing bondo work soo much, it's such a wonderful medium to work with.
    Looking incredible :dremel::jawdrop::rock::rock:
  9. kim
    kim hardware addict
    10 Jan 2016
    yeah :jawdrop: your modding skills can be compared to surgical procedure, fantastic work and daunting accuracy :wallbash: I'm a big fan
  10. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Thanks Gress, yes this build is only for SG-Fans :hehe:
    @DEFYaNt thank you too. What is bondo? Google say only ist a City.
    And Kim thank you very much i give my best :rollingeyes:
    And on it goes, I completely forgot that the Modding Masters already on 2.-3.6.18 is.
    I really wanted to be done so now we have a Deadline.
    As I mentioned earlier, there was a lot to fill and to grind.
    The IO panel should still be clad with ribs, after long thinks whether Plexi or Alu I have decided jokingly for a PVC design flooring.
    The surface is like everything else slightly arched, so I was reluctant to bend ALU or Plexi for.
    I then cut this 16 times in 5mm strips, sanded some edges and glued with mounting glue in 7mm distance on the IO panel
    oh so and the Alkesh would then slowly ready for the paint job
    After curing, I then sanded the supernatants, a little more leveled and primed
    As I mentioned in some forums, blue LEDs are not bright enough for the drive so I rebuilt the lens without the holes for LEDs on the back.
    Here is just a white high density LED stripe behind the lens. The effect is really cool because you go blind: rofl:
    but a slight blue tint, I would have been happy.
    I have here now two lenses back with light and dark blue painted but except that the light intensity decreases does not bring much synonymous.
    The blue effect comes only from the reflection of the plexiglass on the side, but the light itself remains white.
    No plan then I'll leave it White.
    so I had a roll of 4mm trim in chrome, they fit perfectly to the front of the Alkesh's.
    Normally, two more lines would cross in the middle, but at this point the Bitspower Dragon is supposed to. As this is very similar to the symbols of Jaffa Tattoos.
    Attached with superglue, keeps bomb
    When I wanted to paint the cockpit, I noticed that the part of times something crooked is so I was allowed to build me a new cockpit.
    Since the moldings are rounded down, I still had everything neatly trowel here
    and so that I can still open the lid properly, the ends were still bevelled.
    Now I've taken a day off the weekend and made various patterns for the Alkesh.
    then plotted out
    and glued on the Alkesh
    I then primed all of them and painted them in a dark gold.
    Just like other surfaces.
    If anyone knows the Tel'Tak, guess what I intend to do ;)
    Well, I experimented with circles and ellipses for a while until I had the radii of the Alkesh.
    These were then plotted out.
    and then stuck to the Alkesh.
    Yes, and that was not easy to get both sides top AND bottom identically. : Banana:
    in parallel, the gold-painted decals were taped again so that only certain areas remain gold.
    The lines are almost exactly the same, the foil is removed later so that only the lines are gold
    partly also other decals were set which are only painted and then visually stand out from the surface.
    So that the color does not run under the foil later on, I painted all the relevant spots a few more times in gold.
    Well, just before then I primed everything again slightly. This should dry now that I can once again sand everything with 600 wet and can check off the final paint.
    The Alkesh is now painted in silver and then the whole spaceship gets a Washing Effect (YouTube)
    As I said before, a dark gray would be the right shade, but with gray I just do not have the metal effect, so it's now painted silver.
    See you next time, now it's moving forward :cool:
    _Prometheus_ likes this.
  11. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Here I am again.
    This time there were many low blows but it goes ahead.
    Where had I stopped?
    Achso, the Alkesh I have now completely painted outside silver.
    and then remove all the tapes.
    Although the film is good for masking because no color runs behind but the paint has decomposed the film that remained the adhesive on the spaceship.
    In addition, you needed so much power to remove that I went to 30% everywhere the color with.
    In the dark places you can see very well the glue residues here.
    Okay, so only the removal of the residue has cost me smooth 3h and from the repair of the paint damage, we need not even talk.
    All affected areas taped again or partly plotted first and repainted.
    Now it was up to the interior and the MB Tray.
    At first I painted all of this anthracite,
    and then sprayed with two colors, silver and white, marble effect spray. I've put a few shades with gray and black shadow spray and provided everything with a gold glitter spray
    the very end I still have sealed everything with semi-gloss varnish.
    The cockpit I have set off laterally in gold
    then finally the upper bracket glued to the acrylic tube.
    The rings of the drive could now be glued to the scattering lenses.
    Before that taped so that the diffusion lenses when washing effect not be dirty.
    Now it went to the LEDs for the drive.
    Without words, I have tried other LED positions but this is the best choice.
    I then stuck the stripes in the drives with hot glue
    and from the inside everything still wired clean.
    on the door to the PSU I have drawn lines with a golden edding
    before I stuck the pillars on it. Superglue is just perfect.
    Cooooooool :love:
    now something went on in the interior.
    Fan PSU and a few Fittings mounted.
    The HDMI connection by itself and the USB 3.0, I fixed with hot glue and then poured completely with epoxy glue.
    I was able to solder the 230V extension of the SFX Revolution.
    On sunday it finally got to the cable.
    Probably the shortest extensions I was allowed to do.
    First, the 24pin ATX cable to about 10cm.
    then the PCIe cable to 20cm, because the original would be too short.
    And the 8pin EPS cable I could 1: 1 sleeving.
    Ahso and the pump cables are the same.
    I do not even know where to start but I have so much spanking this weekend.
    This is not even the half of the photos I had.
    But without words.
    Yeah the digital LEDs for the bomb I wanted to fix with velvet ring with hot glue from the inside but please let brain rain.
    The hot glue has of course destroyed the whole shape :wall:
    Well for the bomb, I've still cut a base plate, chamfered the edges and also immediately painted black.
    The cockpit I have now provided with Goa'uld font, but without meaning, there would be no room for it.
    I then opted only for optically matching hieroglyphics.
    I have dissected a light cord, which I originally wanted to use but then discarded again, and found that lead the only one strand for the mass.
    Just soldered some cables.
    Because of the split tray, I need two cords, but have only bought one and did not want to install two extra separate.
    This should then serve as edge interior lighting.
    okay, I then soldered the second string to the controller and it works, yeah!
    Via 5V
    Okay for the 5V still a small distributor made in black
    glued a 3pin connector to the PCB and soldered it to the battery poles.
    Yes and I wanted to use these homemade combs for a long time xD.
    Sorry that no sharp photo at is when you always double photographed everything on cell phone and camera does that happen.
    I simply screwed the entire board to the tray from below with a plastic spacer.
    Before, of course, the holes drilled in the tray.
    I also find cool on what you do not come for ideas if you have a long time. :rofl:
    Okay and then I stuck the string to the tray, fixed it with adhesive and then reinforced it with epoxy glue from the outside.
    Sorry at such late times I'm always really unable to shoot sharp photos, too dark too much energy drinks and so on
    Slowly I'm running out of ideas.
    Oh yes, there was something else: crystal control panel, but first I want to finish the coating so that all tapes can go away.
    The pyramid still has to be polished, the bomb is still to be programmed and otherwise only minor things
    THX a lot
    Capten​
    Dot_Kappa likes this.
  12. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Dude the level of detail on this is crazy. So many good ideas too.
    Serious Kudos. Looking forward to seeing more.
  13. David
    7 Apr 2009
    This is looking sooo good. Stunning work.
  14. lowfat
    lowfat Minimodder
    4 Jul 2013
    Nice work so far. :rock:
  15. adidan
    25 Mar 2009
    Looking awesome.
    One thing is troubling me though:
    :jawdrop::lol:
  16. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Thx guys!
    Lets go, it was a bit stressful the last two weeks but it was worth it.
    That's what he looks like now the "Washing Effect".
    I have used black acrylic paint for this and also some of metallic effect colors on acrylic base (black, silver, anthracite, gold)
    The colors are simply diluted down to water, applied, and then wiped off again with a fuselage-free rag.
    Depending on your preference you wipe them in some places more on others less down.
    This results in a very nice wear effect after 5-8 passes.
    Unfortunately, I could not count because I was very often dissatisfied and the colors have completely wiped down.
    As always there were some problems:
    - Water colors or school colors do not work, they dissolve each time you work again
    - as the first colors are permanently beaded off the rim varnish I sanded the Alkesh again completely with 1000 sandpaper.
    Since the curves pardu did not want to get darker, I felt different here.
    I wrapped the rag around my index finger, dipping the finger lightly into black undiluted paint and distributing it evenly.
    But in very small steps so max 5-10 square centimeters.
    Immediately after applying, I began to beat the color like a madman with a finger.
    This resulted in this beautiful hammered effect. :love:
    Okay, after I had finished, I stuck the interior completely off and painted the whole Alkesh Clear.
    After the third Goa'uld bomb was finally finished I was able to deal with the programming of the Arduino
    I like it. I also had a short video of it on Facebook uploaded
    The control for the light string I had provided with the hot glue, then it was quiet.
    Unfortunately, it was suddenly loud after installation. Try the whole thing again with candle wax.
    The whole control I do not want to pour only the throttle.
    Okay, when I touched the Al'Kesh one day later I realized that I had applied a lot of dirt with the "washing effect"
    So everything was ground again smooth and once again painted clear.
    On the bottom plate, I put a Chrome logo as a Tauri sign and the sponsors to match in matt gold.
    For all the RGB LEDs, I have tinkered with a small distributor to control all over the Motherboard.
    so for the cockpit I put a yellow LED in a small reflector
    took me a small bulb and made me with the thermoforming of it an imprint.
    I then cut it into shape and stuck it on the reflector
    then painted in gold
    To recognize something bad, but finally, after the foil was removed from the pyramid, I polished the cut edges of the window
    The reflector I stuck now in the cockpit, previously drilled a hole for the cable of course
    So now Tialc also has a steering wheel to fly XD
    The Arduino was now soldered to a board, in addition to the LEDs of the bomb, I still put the connection for the yellow cockpit LED and the drives.
    Finally, I glued a 3mm Plexiglas plate with hot glue from below so that there is no short circuit here.
    Well the cables are all sitting, time for hardware installation.
    There's not much to say about cutting tubes.
    For the ball valves under the Alkesh I cut two 4cm tubes to 45 degrees.
    and then edited them with the Bunsen burner.
    The effect is super cool. We would then have the mouths of the ship's cannons.
    Again, no photo ... ****.
    I feared that the ball valves with Q-distributor would be too big for the Al'Kesh but quite the opposite.
    They fit perfectly.
    Okay, at least something I photographed.
    The finished loop :love:
    Soo we went to Modding Masters in Friedrichshafen.
    I had not registered the Alkesh because the ROG Carbine was not there yet.
    This won but smooth the first place for scratch build and additionally the audience Award.
    YEAAAAAAAAH !
    I still had a Casemod at which there is not even a worklog and also this one won the second prize. Really unexpected because I just cobbled this just for fun together.
    But since there has been something in the case for over a year, there was plenty of work in it.
    Okay, I really do not want to torment you, but it should still be a little exciting.
    The holder for the Alkesh made of 8mm Plexiglas was a bit shaky for me.
    It has held but also the orientation does not tell me so completely so I started yesterday just after the car unload a new bracket from 1cm thick Plexiglas to build.
    First cut the bottom plate again with the jigsaw
    and then chamfered edges and polished the same everything.
    Then I cut the star, the chamfering, bending and polishing will come tomorrow.
    Okay that was it again, a few little things are still to be done, until Gamescom I have so much time again :D
    cobalt6700 and _Prometheus_ like this.
  17. ronny78
    ronny78 Minimodder
    13 Aug 2015
    Sooo the wait is over.
    Here is the last update.
    Next it went to the new 1cm bracket.
    After all edges were beveled I bent them now differently to change the angle of Al`kesh something.
    So it feels a bit more coherent and you can look much better into it.
    The whole pyramid was now covered with frosted glass foil,
    really took a while until I had created a design which optimally fits the transparency and now
    the pyramid is not quite as invisible as on the Modding Masters.
    More photos will be available at the end of the article.
    Now I took some time to design a few decals for the bottom plate.
    This time it's the original Goa'uld font combined with the sponsor logos.
    After these were transferred to the base plate, she got anti-skid and finished.:love:
    Now the first outdoor finalpics.
    With the lighting you have to wait a bit, after removing the hot glue of the light string control it will not work anymore.
    I have already ordered new but unfortunately, the earliest comes until the end of this month.
    The system is running anyway, OS is not on it yet.
    After one or two hours of bios, the temps were at 36 degrees, which I find okay for two 120mm Slim.
    But see for yourself, what do you think?
    Okay, so if I look at this myself I think it's pretty PORN: banana:
    Yeah I finally have an AL`KESH: D
    For the drives, I had extra with a 9Volt battery taken but the performance was unfortunately not sufficient despite cloudy day.
    Well, no matter what you see at the next indoor photo shoot.
    Hope this happens this month but now I have to move on to the next project.
    This time again a Casemod name "Anubis" :hmm::d​
    Dot_Kappa, adidan and _Prometheus_ like this.
  18. kim
    kim hardware addict
    10 Jan 2016
    :jawdrop: fantastic work, and wonderful result :wallbash:, I've just spent an hour watching and reading it all again from the start, it's a real lesson of modding and creativity, can't wait to see what Anubis will be, you've got a fan :grin:
    ronny78 likes this.
  19. adidan
    25 Mar 2009
    I think you just have to look at the detail on the stand to see how good this is.
    I love attention to detail. Great work.
    ronny78 likes this.
  20. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
    Awesome work! :dremel:
    ronny78 likes this.
