Rant God it hurts!
Discussion in 'General' started by chrisb2e9, 6 Jun 2012.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I had my bottom wisdom teeth out last Tuesday(again, turns out I had two sets on the bottom(and none on the top??))
    and on the left side I have a dry socket. It's a huge hole in my jaw! If I open my mouth you can see my jaw bone. And does it ever hurt! On 30mg of codeine and 600mg of ibuprofen. Was also given a gel called sockit (http://sockitgel.com/Home.html) to fill it but it doesn't last very long.
    I wake up in the middle of the night when the pain killers have worn off and pop two pills of codeine and one of the ibuprofen. It takes about an hour for them to kick in to the point where I can fall back asleep. This is seriously the most pain I have ever felt in my entire life.
    And god forbid someone look at me the wrong way because I have become such a ***** from the pain and drugs.
    Just ranting. would like to punch someone/something but the last thing I need is a broken hand as well.
    /rant
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Would not Bonjela help numb the hole? Might be worth a shot if nothing else...
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm guessing that Bonjela is a name for a benzocaine solution for tooth pain. If it is, grab some. When I had my teeth out, it saved me from insanity. (Granted, I had ALL of them out at once, but that's what a fast moving necrotizing infection does to you.)
    Hot salt water tastes like ass but relieves some of the pain. Hot compresses helped too. Room temperature drinks (if you can stand them) helped immensely too. I fought it off and on for about seven years before they finally just took them all and the infected bone/muscle. So I feel for you. Dry socket sucks hardcore. And many dentists will refill pain pills if you get one, cause they hurt so bad.
  4. chrisb2e9
    18 Jun 2007
    Looks like Bonjela is a UK thing?
  5. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    I tend to eat the full tube of Bonjela...
  6. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Ask your doc fro some trammadol
    Sent from my HTC Sensation XE with Beats Audio using Tapatalk 2
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    didn't have a dry socket but remember them sending me home with info on that.. wash with a lot of salt water.. tooth particles come through the gum, it's weird but nothing to be alarmed about- your gums will form around the sharp bone that's left and it'll eventually heal
    really not as bad as it seems.. should have sent you home with gauze to chew on till it clots up good.. dentists make a bundle cause they know a lot of people just can't take pain and will be back for another visit.. I just used 2 tylenol every 4 hours and that was good enough.. they prescribed vicodin xD noticed a lot of people take the gas too- I don't like waking up with pants unbuttoned so went with the novacain (like a boss) and walked out with a mouth full of gauze
    the only weird part is the bone that makes it way through the gum- chips of bone.. think my filipino healing factor is out of control though- so might not be the same for others with more monkey genes.. might as well give some fundamental tips too- avoid surprise buttsecks like the plague using gaydar
    if it's going off all the time.. it's probably because your about to be surprised- from behind or the side.. take the defensive position
  8. Akkatha
    Akkatha *SCREECH!* /run away.
    26 Aug 2009
    Clove oil.
    I had a pretty bad dry socket after I had a tooth pulled and that was the only thing that properly stopped the pain. Tastes like hell and kinda burns your lips if you get too much on them, but if you put some on cotton wool and bite down on it then it will give you relief.
    Was a lifesaver for me! It'll pass mate, but it really is one of the most painful things I've endured too.
  9. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    +clove oil.
    it's amazing stuff.
  10. GMC
    GMC Minimodder
    26 Jun 2010
    Three words...
    Single Malt Whisky......
  11. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Sorry, can't help you. I am hated and despised by virtually every adult I've met regarding wisdom teeth, 3 out of 4 are through and I've had roughly 4 minutes of pain once. :D The missus swears by clove oil though.
  12. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I've got all four wisdom teeth and only ever had a mild ache :p The other half had a fair bit of pain with hers though. A lot of paracetamol was taken.
    Teelzebub likes this.
  13. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    11 replies and still no-one's mentioned the grocer's apostrophe in the title?!
    That's the real painful thing going on here! :D
  14. Krikkit
    21 Jan 2003
    Maybe they were worried about the OP finally having a mental breakdown and killing them? Corrected anyway. :)
  15. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    This
    Preferably cask strength, somewhere around the 58-60% mark (by vol), but obviously this may affect your driving!
    Also +1 on room temperature fluid, ideally just water & nothing else, keep swishing that around. I also used Corsodyl, which helps keep it clean like the whisky does but doesn't leave you stinking like a distillery.
  16. Shirty
    18 Apr 1982
    Bonjela won't touch it (wrong ingredients) - and it's not available in North America anyway. I do feel for the OP though, I've always been very lucky with my teeth (touch wood) but I've seen my dad go through some serious pain :(
    Oh, and I have all 4 wisdom teeth and didn't notice them popping through at all. Props to my childhood dentist who removed my four 1st molars when I was 12. The second molars moved in to fill the gaps and gave the wisdom teeth space to pop out quite early on in my twenties.
    Sorry to rub salt in the dry sockets and all...
    noizdaemon666 likes this.
  17. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    You have my sympathy. Mouth pain is horrid as there is just no escaping it..not that you can escape pain anywhere on ya body, but you can sometimes forget about it.
    Don't remember more than a mild ache when my wisdoms were coming through, and I've not had dentist work done since I've had my adult set of teeth. I've got those horrendous moments before me as my teeth inevitably wear-out as I get older. Joy..
  18. chrisb2e9
    18 Jun 2007
    Yesterday I think I would of been able to reach through the internet and kill someone.
    Today I went to my regular dentist and he put something else in the wound. Everything on that side of my mouth is numb. Sweet relief!
  19. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Clove oil is really the only thing that works!
