Modding God some ideas?
Discussion in 'Modding' started by Laaars, 3 Aug 2004.
  1. Laaars
    Laaars What's a Dremel?
    11 May 2004
    Hi!
    I've got this Lian Li PC65USB wich is slightly modded.
    Now i got some modding-kick again and want to mod it. No extreme modding, but some small modifications that make the overall looks better.
    So, you got any ideas of what i can do?
    I was inspired by this guy who made Orac3, so i have bought some of these prosject-boxes and i'm gonna make some small junction boxes. Maybe some shower-hoses too. (Hope it's not gonna be to rip-off). But i think chrome shower-hoses will be cool in that black case.
    Anyway, you guys have some ideas of what i can do? Small og large ideas, it doesn't matter! :)
    Here are some pics:
    Hope for some really good ideas now! :thumb:
  2. kobaj
    kobaj Banned
    4 Jul 2004
    i would change the color of the ribbins at the bottom (turquise :nono: )
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    custom window etch?
  4. funkymunky
    funkymunky Guest
    btw might wanna change title
  5. danmagicman7
    danmagicman7 What's a Dremel?
    11 Jun 2004
    Strip out the old IDE cables and resleave your power cables. Make it all UV and add UV fans and lights. Maybe make everything glow green UV and have blue cathode lights. That would look good :clap: I also like having orange UV and yellow lights.
  6. rankie
    rankie What's a Dremel?
    12 May 2004
    spray paint your heatsinks
  7. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    that wouldnt really be that smart considering paint inhibits the removal of heat from the heatsink
  8. Firehed
    15 Feb 2004
    Anodizing would definately be better than paint, however it doesn't murder performance either, just hurts it a little. It's not something I'd do to a CPU heatsink... maybe ramsinks though.
  9. Laaars
    11 May 2004
    I don't understand this. What do you mean?
    Thanks for the ideas. Maybe i will use some of it. I'm looking for a clean case, not many different colors on the lights and so on. Maybe UV... i'll see. :)
    Got some more ideas?
  10. Firehed
    15 Feb 2004
    I think he means the rounded cables' color.
  11. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    Laser LEDs to light the motherboard at varying angles maybe?
  12. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    uv markers are always cheap fun and simple, fallow the traces on your cards mobo, maybe spary the whole insdie with clear uv paint and add a 12" uv cathode
  13. Nath
    28 Dec 2003
    /me imagines Laaars showing people his new case then them recoiling as their eyes are burned into small lumpy deposits....
  14. blue_fusion
    blue_fusion What's a Dremel?
    3 Aug 2004
    Maybe take everything out of your case and paint the interior. You should paint the interior like blue to match your rounded cables. Just a thought
  15. Nath
    28 Dec 2003
    Good idea blue! Welcome to bit-tech too! :thumb:
  16. Laaars
    11 May 2004
    Thank you! :)
    I've tought about doing something to the inside, or the "walls" in the case.
    Maybe paint it, yes. Or maybe add some aluminium-plates (at least in the bottom) wich is polished, like a mirror. :) I can hide cables and stuff under it too.
    Like a false floor.
  17. crash32953295@msn.
    crash32953295@msn. What's a Dremel?
    2 Aug 2004
    1. spray your case inside
    2. new mobo (lanparty with uv)or spray paint current one
    3, lighted fans
    4. mod th zalman thing put another fan on or summit
    5. find a theme for the computer, usually unique one
  18. Laaars
    11 May 2004
    I don't want too much light in there. I want a clean and stylish case. :)
    First of all i shall get rid of all the cables. And sleeve all the visible cables and put a silicone-tube on it.
    Maybe some shower-hoses on the power cables to the HDD's and stuff. Maybe i'll find something else, but i like the shower-hoses.
    I can't decide if i should have UV light. Then i'll go for the Lanparty mobo and paint the circuits on the PCI-cards.
  19. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    just a sugestion. How about adding full water cooling and geting rid of those fans (well most of em)
    Thats a nice case btw.
  20. Laaars
    11 May 2004
    Watercooling would be nice, but i don't think i will use that much money on it. But maybe if i can make the WC myself. Me and a friend shall try that now, so if that become a success maybe i will make one to my case. :)
