Motors gokart problems
Discussion in 'General' started by darkhunter, 23 Dec 2005.
  1. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    my mom ordered a gokart for my brother for christmas it came in yesterday and I spent the whole day building it poured some gas in it then started and let it idle for about 20 min. after that I took it out for a spin and ran out of gas(figures) after running back getting gas bringing it back ect then having to push it back because it wouldn't start. again once I got it into the garage it started then shut it off for the night. now I come back this morning and it won't start and sometimes makes a rapid clicking noise. any ideas?
    oh yamaha 250cc water cooled engine
  2. Tibby
    Tibby Back Once Again
    9 Oct 2005
    you changed the intake?
    I don't know if it is the same on go-karts but on bikes theres like a little valve which lets more fuel in.
    I don't really know much about these things, just something I remember, I am sure a more able member will have some sound advice.
  3. Kernel
    Kernel Likes cheese
    29 Sep 2003
    I sometimes work as a side Mechanic for Ancaster Karting which might help :D
    I will assume you checked oil and you are using the right grade.
    Check the gaps on your spark plug, off the top of my head your are looking at a gap between 0.8-0.9mm.
    Check fuel lines for any blockages, can becaused by sediment in the tank going in to the pipes when it has been run dry.
    When it was first built did you rag the crap out of it from new or have you been gentle with it?
  4. darkhunter
    13 Apr 2004
    I was gentel with it the motor came pre assmebled and I am going to check that stuff now
    nope none of those are the problems, it sounds like its stripping a gear after a few seconds trying to start it. I am assuming this is a bad sound
  5. slater
    slater Mummy Says Im Special
    18 Apr 2003
    A rapid clicking noise? only thing i can think of making that noise would be the starter or maybe clutch.
    Its a pull chord type starter? with auto clutch? 4 stroke?
    What kind of thing does it do when its not starting? does it just refuse to do anything? dose it almost go but not quite? are you chokeing it? if so what differance does it make? When it starts does it start easly?
    could be anything by your description im afrade, sounds like the starter isnt engaging properly tho
  6. Kernel
    Kernel Likes cheese
    29 Sep 2003
    I'm not entirely sure I can't really tell without hearing it.
    What model engine is it?
    I am more familiar with Honda GX270 engine.
  7. darkhunter
    13 Apr 2004
    when it starts it starts eaisily. electric start yes the clicking noise is from the starter 4 stroke auto clutch
    http://store.pocketbikewholesalers.com/kd250fs2.html
    update: the clicking noise is coming from a box in the electrial line this is a black plastic box when I try to unscrew it sparks can be seen from inside and after stopping that there is no power to anything anymore
    please help I am worried that I screwed something up really bad
  8. darkhunter
    13 Apr 2004
    ok re tightened one of the screws can't reach the other one to retighten still no power
  9. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Mmm, erm I am running out of ideas, although the Buggy looks mental!
    I think you may have to try the manufactuer, I really can't think what the problem might be. Sorry dude. Hope you get it sorted for your brother.
  10. .308AR
    .308AR What's a Dremel?
    8 May 2005
    You need 3 things. Air/Fuel/Spark. Check the battery. It should have 12-14 volts. If less than 12, charge it. Try removing the spark plug and place it against the engine block. Try the starter and check to see any sparks. DO NOT TOUCH THE PLUG OR ENGINE. Put your hand over the spark plug hole and crank the starter. You should feel gas splashing on your hand. If no sparks make sure the kill switch is in the run position. If no fuel check the lines for blockage. You may need to bleed them. Check the fuel/air mixture. Put everything back together. Remove the airbox lid and check the filter. Try to start it without the lid and filter. If everything checks out and it starts replace the filter and lid. If it won't start spray a LITTLE ether (aka starting fluid) in the airbox. It should crank up and idle fast for a minute.
    Have you called the seller?
  11. RepLiKa
    RepLiKa What's a Dremel?
    21 Aug 2004
    Please tell me you ran the engine in...
  12. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    flat battery FTW
