Hey all. Couold you guys help me look for a good luking decent black case that would be suitable for modding? Also, any got suggestions to name the computer? i want to integrate it into the case somehow. thx guys
if you have £80 to blow, i would go with the lian li PC-61. gorgeous case, good for a tasteful minimalist mod.
and make a good couple with either Prommie or Vapo units If u want quiteness, then Antec Sonata is a strong contender (with its 2x120mm fans over Lian's 80mm air suckers/blowers )
get yourself a nice lian-li case ( pc-65b) and a dremel and have at it, or as stated above get the 61 case if you dont want a factory window
hmmm, i would like to spend under £100 because this would be the fist case that i would try and mod and noing me, i have loadsa ideas but ill screw the case up.
go for the lian li mate, theyre great cases, make your life so much easier with removable mobo tray etc, change the intake fans and outtake for coloured jobs, bung some uv caths in, uv sheath your cables etc, great case to start with, (i can hear the moans from all the old modders out there with my description, but for your first case it does look effin lush!)
If it's your first case and are worried you might mess up an expensive one, ebuyer.co.uk have some great cheap cases for moddage. The coolermaster centurion has a lot of modding potential and is only around £40. Alu front and steel chassis. If you'd rather go for a nicer alu case, some of the lian-li cases are nice, as are the coolermaster ones.
i'd go for the antec sonata myself. good PSU with it and capable of 2 120mm fans. and i like the hdd mounting system
