Good buy?
Discussion in 'Hardware' started by robbybertu15, 28 Dec 2005.
  1. robbybertu15
    robbybertu15 <b>needs a job</b>
    28 Feb 2005
    I'm looking for a new CRT monitor. I found This
    but is it a good buy? Any suggestions for a high resolution monitor for gaming?
  2. Pookeyhead
    30 Jan 2004
    At it's current bid price, yeah!
    AT $99 dollars, it's still worth a look. Dig out some specs on it.. a good 22" CRT should be able to do 1600x1200 @ at least 85 Hz. If not, then forget it, as you wouldn't want to run less on such a large screen - what would be teh point?
  3. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    o_O i run 1280x1024 on my 21" CRT monitor. 1600x1200 Is way too small, even on such a large monitor.
  4. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    What a waste... I run 1600x1200 on a 19" CRT and it's great
  5. jpaturzo
    jpaturzo What's a Dremel?
    25 Mar 2005
    Man, 70 bucks shipping is rough. My 21" IBM P260 cost me $75 at a local surplus outlet and about 3 dollars in gas to get home. It weighs about 60 pounds. Check locally before you drop that kind of cash.
    For the record, I use 1880x1440 at work on my 21" Dell CRT, and 1600x1200 at home on the IBM.
  6. Pookeyhead
    30 Jan 2004
    Really? It should be pin sharp at 1600x1200. If I run 1280 at work on my La Cie 21", it looks stupid! Anything less than 1600x1200 is a waste of a decent 21" monitor. You sure yours is OK? Or do you mean you just prefer it larger, but it's perfectly sharp... just a personal thing?
