Small Form Factor Good Configuration in case (Silverstone/Lian li)...
Discussion in 'Hardware' started by cooljojo, 23 Jul 2010.
  1. cooljojo
    cooljojo What's a Dremel?
    23 Jul 2010
    Hello All!
    Hope you're fine! :baby:
    I would just need some help from you. Those accustomed to SSF.
    I plan to build a SSF configuration for an HTPC and GAME machine, and these are the component I want:
    - GA-H55N-USB3.
    - Intel Core i5-670.
    - An reliable, silent CPU cooler/fan (H50, Shuriken, AXP 140 ?).
    - G.SKILL Ripjaws 4GB 240-Pin DDR3 SDRAM DDR3 1600.
    - ATI HD 5870 (Later :p...).
    - I plan to put a 3,5" SATA HDD and/or a SSD drive.
    And here is my problem, I am hesitating for 1 week (by reading many review or forum thread) about what case to take:
    => Silverstone Sugo Sg07 or Lian Li Q08 ? :confused:
    What do you recommend to me please ?
    Thank you very much for you precious help. ;)
    See you,
    Jo.
  2. cooljojo
    23 Jul 2010
    Someone could help me to decide please ?
    I'm also wondering which case (SG07 or PC-Q08) present more compatibility with the different CPU cooler.
    Thank you !
  3. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    I don't know much about the Lian-Li, but for the Silverstone, bit-tech's review features this tidbit about cooler clearance:
    I hope it helps. I'm not very familiar with small form factor stuff, so I'm afraid I can't give you any more advice.
  4. cooljojo
    23 Jul 2010
    Thanks for your answer sheninat0r !
