good gaming keyboard?
Discussion in 'Hardware' started by rito, 6 Dec 2007.
  1. rito
    rito What's a Dremel?
    19 Sep 2007
    does anyone know of a good gaming keyboard that supports at least four keys simultaneously?
  2. rito
    19 Sep 2007
    bump, i can get away with it only supporting 3 keys simultaneously.
  3. iddqd
    iddqd What's a Dremel?
    6 Feb 2006
    Any keyboard can do 3 keys simultaneously... I used a generic old eMachines keyboard and was able to use ctrl+shift+space all at once.
  4. Jazza
    Jazza What's a Dremel?
    4 Dec 2007
    i like the saitek eclipse II its at a reasonable price of £32 great keyboard with three diferent LED colours can be blue/red/green whichever and whenever you want it to be. Great for lights out gaming
  5. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    I very much like my Logitech G11 keyboard. Didn't feel the need to go for the G15 with the readout. I'd recommend it to anyone needing gaming macros and other good stuff.
  6. Kurayamino
    Kurayamino As long as the Raven flies
    5 Sep 2005
  7. amdboy89
    amdboy89 What's a Dremel?
    15 Nov 2007
    Not to mention the infamous ctrl+alt+del combo...even with all the generic keyboards I've used.
    The 2 keyboard that come to mind when used in tandem with gaming; the G15 and the Tarantula
    Now I don't know much about the G15 but the Macros are a nice added advantage to any gamer. And they are aesthetically pleasing.
    I do however have the Razer Tarantula and I love it. As said earlier you can press 10 different key simultaneously, it’s comfortable, and you have 10 Macros as well as the 15 media keys. With the Razer all the keys are programable and I believe that It will store 5 different profiles onboard and even more on the computer!
    Only problem with these keyboards however is they are a bit pricey.
  8. Kurayamino
    5 Sep 2005
    You forgot to mention they contain gold :O GOLD!!!!
  9. rito
    19 Sep 2007
    i talking about something in the $20 range.
  10. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Razer Tarantulas and Lycosas can do 10 keys at once, and Logitech G11/15 probably can do something like that too. Any generic $2 keyboard will do 3 keys at once... nothing special there.
  11. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    My keyboard allows shift + W + D but not shift + W + A :confused:
    Still, £5 :)
  12. rito
    19 Sep 2007
    the problem that i have is that i'll press "w+d+space" but then i cant press q,e,r,f or something like that to change weapons with.
  13. Kurayamino
    5 Sep 2005
    Just go into a shop that sells keyboards and ask to have a look at them! $20 is just a standard keyboard, logitech are good!
  14. hammerfall4ever
    hammerfall4ever What's a Dremel?
    9 Dec 2007
    I know that SHARKOON Rush Board is good for games and it cost about 20$-25$
  15. chittes
    chittes What's a Dremel?
    28 Jun 2005
    Don't think you'll get one on that budget, might need to push the boat out a bit more ;)
    Apart from the logitech another reasonable budget option (but still over $20) might be the wolf king keyboard...
    (Review of it here: http://www.itreviews.co.uk/hardware/h1395.htm)
  16. hammerfall4ever
    9 Dec 2007
    SHARKOON Rush Board- 18$ or in other shop 21$
  17. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Any old keyboard will do. I would be surprised if many new keyboard would have problems with 5 keys. The record I have seen is eight keys. Mine can do five. asdfjjjjjjjjjjjj (as you can see)
  18. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Does anyone know how many the Das keyboard can do? And where to get one in New Zealand. I need W, A/D, down, left/right and space or zero on the numpad.
