Good HSF for a 939 3500+ ?
Discussion in 'Hardware' started by cfuk, 28 Feb 2005.
  1. cfuk
    cfuk What's a Dremel?
    9 Jul 2004
    I'm down sizeing my case, so i don't think i'm going to go down the water cooloing path. I need a good hsf to cool my A64 (939) 3500+ as i'm only using the one you get with the reatil set. I have a MSI K8N Neo2 Platinum so i think the Thermalright XP-120 is a bit to big for the board.
    I hope you can help :)
  2. atanum141
    22 Jul 2004
  3. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    XP90 imo, fit the board fine (as long as you dont have any really tall mem like the corsair pro) Coolings great, and you can stick whatever cfm/noise fan on you like to suit your needs.
    Either that or the freezer 64 :)
  5. cfuk
    9 Jul 2004
    i had the XP-120 on my old (754) MSI board and it over hung the memory slots
  6. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    xp120 if it fits, otherwise xp90 ;)
  7. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Freezer 64 from what i heave read, and alot cheaper!!
  8. T-MINUS 10
    T-MINUS 10 Banned
    13 Feb 2005
    like everyone said, xp-120 if it fits, otherwise the freezer 64 :thumb:
  9. blah
    blah Minimodder
    16 Jul 2004
    I have an MSI Neo2 Platinum board. If you are interested in regards to silence then the Freezer 64 is the way to go, very cheap and very quiet :clap:
  10. cfuk
    9 Jul 2004
    how well does it cool?
  11. blah
    blah Minimodder
    16 Jul 2004
    My sensors on my board are a load of bollocks so I don't really know. I am not using AS5 either, I am getting temps around 5 degrees lower than stock.
  12. TMM
    TMM Modder
    12 Jan 2004
    I have a Thermalright XP-120 with a panaflo L1A (1700rpm, 68cfm~). The combo is fairly quiet and runs about 6*c cooler then the stock HSF :thumb:
