A/V good in ear headphones
Discussion in 'Hardware' started by exavier412, 4 Apr 2006.
  1. exavier412
    exavier412 What's a Dremel?
    15 Jan 2004
    hey. i'm looking for some good in ear headphones to replace my ipod headphones. i am into music, and like sound quality. i hear good things from the shure in ear headphones, but thats only from advertisements. does anyone use them?
    most of the music that i listen to is in 192 MP3.
    should i spend $100+ on shure's? sound quality is important. but durability is also important. i want them to last awhile.
    thanks.
    -DyLaN
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    Seinhessier (sp!) - 3 different models in our house atm. I normally find in ear uncomfortable but all the seinnies are dead comfy and sound quality is excellent. Not tried Shure so can't compare.
  3. warchild
    warchild What's a Dremel?
    30 Jan 2006
    My vote goes for Shure E2c.
    They are not cheap but, they are a great value and incredible sound.
    ...and the eartips fit perfectly.
  4. mushky
    mushky gimme snails
    24 Mar 2003
    Shures sound great but they block all external noise out too. Great for trains, planes etc but not so good for biking or walking around.
    The e3cs would be my choice as they are a bit heavier in the low down frequencies.
    Other than that, Sennheisers range are pretty good but mine sound awful on my ipod shuffle for some reason. Great on everything else.
  5. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    I'm not sure that you need proper IEMs. With the E2Cs, you pay for isolation, not sound. You can get far better-sounding earbuds for far cheaper, but with slightly less isolation, still plenty to be getting on with though. Look at the 'semi-canalphones', those in the image of the Sony EX71 (but not them themselves, they're awful). Here's my ranking of them. To add to that, I've now heard the Audio-Technica CK5 and I can say they're a bit better than the HJE50s, so probably #4 in that list.
    To sum up - if you want good sound and decent isolation in a cheap in-ear headphone, get the EP630. If you're in the US, the only place to get them is eBay. I bought a pair off eBay and it was genuine, though there are a lot more sellers nowadays. You could spring for the Sennheiser CX300 which is identical, but you'll pay more for the Sennheiser name.
  6. Valo
    Valo Minimodder
    11 Aug 2004
    shure e2 doesnt seem to be worth its price - ex71/51 / ep630/ sharp md33 sound better and their cheaper. but if you have more money to spend gettting iems is not a bad idea. i'd recommend shure e4 and westone um1
  7. Kameleon
    29 Apr 2003
    I'd say the UM1 isn't really worth it but the UM2 definitely is. Otherwise, that's a great summary of my post, apart from the horrible-sounding EX series ;)
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    (Ignoring the lovely spam post above which im sure will be deleted soon)
    Sony MDR-EX71 have been great for me...
  9. Kameleon
    29 Apr 2003
    My first experience with in-ear headphones was also with the EX71. All I can say is, wait till you hear something better. I couldn't believe that an in-ear in the same form factor, with the same price (or in some cases cheaper), from a different manufacturer could sound so much better. A difference of the same magnitude as moving to EX71s from nasty stock earbuds.
  10. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    I have Etymotic Research ER-6, and they sound pretty good. In ear stuff takes a bit of getting used to them though.
  11. Naked_Dave
    Naked_Dave What's a Dremel?
    30 Nov 2003
    I have the Shure e5c, the main competitors to the Etymotics above. Either are great, depending on what type of music you listen to most, but the cost can be prohibitive.
  12. Altron
    Altron Minimodder
    12 Dec 2002
    But DO NOT buy e5cs. The new e500 will be arriving in June, and they are worth waiting for. Same price as e5c, but more comfortable, better sounding, and a removable 'push to hear' thing that is great! It's a goofy box with a mic, pressing a button cuts the music and amplifies the mic, so you can have a conversation without going through the trouble of removing them.
  13. Naked_Dave
    30 Nov 2003
    Harder to get cheap second hand though :)
  14. Altron
    Altron Minimodder
    12 Dec 2002
    Alright. Don't buy e5cs new though.
  15. ozstrike
    19 Sep 2004
    I really don't know why you would want to buy in ear phones second hand. I guess you could buy new seal thingies, but it would just be a bit sick for me.
  16. Naked_Dave
    30 Nov 2003
    With the more high end ones like the e5cs, only the end part actually goes in your ear, and those are disposable, so there are no hygene issues.
