Networks Good PCI-E Wireless card (MIMO?)
Discussion in 'Hardware' started by [PUNK] crompers, 9 Oct 2010.
  1. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    Unfortunatley i no longer have enough pci slots left for my X Fi and my PCI wireless card.
    So I need a decent PCI-E card for under £20,
    i dont have a router for "n" though, so would it be better to get a b/g MIMO card, or a b/g/n card? My current card is mimo and works very well
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i am looking for exactly the same thing, except it should have amazing windows 7 drivers, because all the cards i have have royally crap W7 drivers!
  3. [PUNK] crompers
    20 May 2008
    yup i tried an airpace with that problem
  4. Burnout21
    9 Sep 2005
    Avoid belkin, linksys looks interesting...
  5. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    I don't have any to recommend but I had problems with the drivers for windows 7 on my wireless card. It claimed it was compatible and I found some drivers but they were awful and windows wouldn't auto detect/install any drivers itself.
    After some investigation I managed to find out who actually made the chip on the card (it was Atheros) and manually installed the drivers through device manager since I did that its been absolutely fine, no problems at all.
  6. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    ah yeah atheros, you can use the generic belkin driver that comes with vista/win 7 for that
  7. koola
    koola Minimodder
    11 Jul 2004
    Agreed, I gave up and now run a cable. It's 100% hassle free now :)
  8. Burnout21
    9 Sep 2005
    I've had no such luck with them at all, it installs and allows basic internet usage, but as soon as i try to torrent my 'nix' distro's it hard locks W7.
  9. Krikkit
    21 Jan 2003
    Airpace can be made to work just fine, have a search through the forums. I found the solution for mine when W7 RC was out, still using it to this day. :)
    Otherwise I'd get an N-card without doubt, no point buying a G card anymore with N becoming the standard.
  10. Burnout21
    9 Sep 2005
    done the same until i can solve the problem. What gets me is the lack of driver support considering how long W7 has been out.
  11. Krikkit
    21 Jan 2003
    Imo the fault lies squarely at the feet of the vendors - MS published what the upcoming driver structure would be like for Vista/7 years ago, yet no-one bothered to get decent drivers going.
    ATi and nVidia I can forgive because they had to write a million lines of code, but a driver for a network card is much simpler.
  12. Burnout21
    9 Sep 2005
    that's the big problem, the vendors want to push there new products and yet disregard there old customers. From what i believe even new products are still suffering bad drivers.
  13. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    best bet to get a USB WiFi card.
    I use this card from Germany. It is amazing make sure to turn down the power if you don't need it, as it is a extremely powerful WiFi card.
    http://cgi.ebay.co.uk/TP-LINK-WLAN-...ie_Netzwerk&hash=item35ac5084b3#ht_7010wt_992
    comes with 8dbi antenna which usually sets you back 40 pounds on its own!
    (use on a 50-100m connection between buildings, with line of sight though)
    Sorry I use a earlier version of this card/USB stick:
    http://cgi.ebay.co.uk/POWER-150Mbps...ie_Netzwerk&hash=item3cae09c3f0#ht_6545wt_983
  14. [PUNK] crompers
    20 May 2008
    ive just tried those drivers but the card isnt being recognised krikkit, pretty sure its a dud tbh.
    call me old fashioned but i'd like to have the card inside the case, usb can get knocked out or worse snapped off in a port. plus ive never seen a usb wireless card that gives as reliable a connection, although to be fair that does look like a serious piece of kit.
  15. Krikkit
    21 Jan 2003
    Sounds like your Airpace is duff then unfortunately.
    I agree completely with you about USB wireless adapters though, I've had about a 50/50 success rate with them, even then they're just not as reliable as PCI/PCI-e cards imo.
  16. Burnout21
    9 Sep 2005
    Smells like your advertising tbh....
    I bought 3 12db antenna's from china few months back for the grand total of £8 including P&P, they turned up a week later and when i got them i took the gamble and it paid off.
    There perfect antenna's, which shows you just how over priced any antenna is off the shelf in Europe considering they've come from the same source.
  17. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    Would this D-Link PCI-E x1 card do?
    It wasn't available when I built my HTPC so I didn't get one but my experience with D-Link routers has been pretty good. No idea about whether the cards are good though.
    Saying that, Win 7 installed my PCI Edimax 802.11n card perfectly without the driver CD - same goes for the onboard Wi-Fi on my Asus gaming rig mobo (late 2007 vintage), Win7 Update automatically installed the necessary drivers (something Vista couldn't manage). So I'm guessing Win7 should find the necessary.
  18. [PUNK] crompers
    20 May 2008
    whao there! £60?
    for that i may as well get an Asus Xonar PCI-E, ditch the x-fi and continue using my pci mimo card
  19. Tasslehoff
    Tasslehoff What's a Dremel?
    25 Jan 2010
  20. storm_technology
    storm_technology What's a Dremel?
    18 Oct 2010
    An ASUS WIRELESS NIC 300Mbps PCI-E x1 PCE-N13 doesnt look to bad for the money
