Other Good Rig for £1500? please look
Discussion in 'Hardware' started by happysack, 10 Dec 2010.
  1. Jipa
    5 Feb 2004
  2. happysack
    happysack goodateverthinger
    19 Dec 2009
    That really helpful link mate thank you im checking it out now!
  3. urobulos
    urobulos Minimodder
    13 Apr 2010
    Even with Sandy Bridge coming out next month, the linked build is still perfectly solid, though I would put a GTX 570 instead of the 480AMP!. Or if you feel like you want to go overkill and really need to spend 400pounds on a GPU then the 580 will fit the build much better.
    First Sandy Bridge CPU's will be mid range parts replacing the i5 line-up, but after listening to the bit-tech podcast it seems the 2nd gen i5's should perform close to current i7 lvls for much less money and lower power usage. Though this is speculation from me at the moment.
    Some will also say to wait for new AMD cards, but tbh I will be amazed if they prove to be more than even or just marginally better than the 580/570 line up.
  4. happysack
    19 Dec 2009
    ok thanks for reply mate. i didnt want to wait anyway!!
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    Please, please answer this question happysack:
    What is the computer going to be used for?
  6. djzic
    djzic Bokehlicious!
    8 Nov 2010
    yeah, awnser the question punk :D
  7. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
  8. Pete J
    28 Sep 2009
  9. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Well if his computing ability is as good as his English then we are in for a real treat.
  10. happysack
    19 Dec 2009
    Sorry I use tapatalk from my phone and iPhone language is junk. Some 3d some rendering. I need to
    Get some software though! Also some games, bring on crysis 2 already!!!!
  11. murraynt
    murraynt Modder
    6 Jun 2009
    24GB of ram for SOME rendering :eyebrow: Seems like a bit of a waste to me.
  12. padrejones2001
    17 Jun 2004
    So does paying $1500 for $900 worth of components.
