Modding good source for foam?
Discussion in 'Modding' started by notatoad, 8 Jul 2007.
  1. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    what is a good place to find some foam, about 1-2mm thick to line the inside of my new custom cd drive cage with to prevent noise&vibration?
  2. capnPedro
    11 Apr 2007
    I got mine from eBay.
  3. Cheapskate
    13 May 2007
    Most hobby shops sell 1/16" to 1/4" thick sheets of foam rubber. I'm using some for my build.
  4. headala
    headala New Member
    9 Oct 2005
    Yeah, check the hobby shops; it's called something like Krazy Kraft Foam. :thumb:
  5. Skulldragger
    Skulldragger New Member
    28 Jun 2007
    Foam is also sold as a packing material, insulating material although that is usually a harder foam than you are likely looking for. try a U-Hall store rental shop if you are in the US
  6. TechMo
    TechMo New Member
    8 Jan 2018
    Check these guys out for foam you can order as much as you need that way. :)
  7. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    Foam parties
  8. Nexxo
    Nexxo Queue Jumper
    23 Oct 2001
