Peripherals Good xbox 360/pc headset
Discussion in 'Hardware' started by grritsshawn, 19 Dec 2011.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Okay I'm sadly in need of a new set my turtles died after 2 years of being used.
    So i got $120.00 max. Maybe wireless depends how good I sit about 3-5 feet from xbox and computer when using them.
    I'm a big razer fan(keyboard,mouse,mouse pad,speakers, 5 onza controllers,shirt) ya you get the point but they don't have to be razer brand they can be turtles or MADCATS(trittons) or any brand that is xbox/pc compatible
  2. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
    was the turtle that you had good enough for the job, did it do what you needed to do and do it well enough?
    if so why not just get another one afterf all you knew it worked for ya
  3. grritsshawn
    20 Apr 2009
    Ya it worked well but i want something better to use. The x11s are good for simple gaming but i think now its time to move up to better quality and sound.
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    The Razer Carcharias seem to be very well praised, and very comfortable too, from what I've seen of them.
  5. grritsshawn
    20 Apr 2009
    I've seen them never tested them who. But I've seen the normal ones the 5.1 and 5.1 wireless ones just not sure on the price difference of them
  6. .//TuNdRa
    12 Feb 2011
  7. Exangels
    Exangels What's a Dremel?
    13 Oct 2011
    tritton ax pros
    there 5.1 , 7.1 if u have £150
