News Google patches Chrome '20 Questions' privacy flaw
Discussion in 'Article Discussion' started by bit-tech, 16 Aug 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    How do Chrome flaws effect the Chromium Embedded Framework? Hell would freeze over before i used Chrome the internet browser but with some developers like Valve deciding to use CEF it seems near on impossible to avoid using it.
  3. RedFlames
    23 Apr 2009
    CEF-toting apps will need to be updated too iirc, iirc steam lags behind CEF releases a bit so you might be wating a while.
    Corky42 likes this.
  4. Corky42
    30 Oct 2012
    That makes it even more annoying, it's bad enough having over a GB's worth of memory spread out between 6 different "steamwebhelper.exe" but knowing they're vulnerable and developed by a company who doesn't give a fig about privacy makes it all the worse.
  5. Gareth Halfacree
    4 Dec 2007
    In theory, though, the problem is reduced when it comes to CEF apps: Steam, for example, doesn't load random HTML stuff from third-party sites and doesn't let you log into Facebook with it either, so it can't easily be exploited to figure out who you are from your Facebook details like Chrome proper can.
  6. RedFlames
    23 Apr 2009
    yes it does, or did, via the in-game overlay.
    whether anyone is daft enough to log into bookface via steam's in-game browser is another matter.
    EDIT: security concerns like this is why CCP removed the in-game browser from EVE, it was quicker just to bin it than fix it/keep it secure.
  7. Gareth Halfacree
    4 Dec 2007
    I sit corrected! Never used Steam for owt bar buying and installing games.
Tags: Add Tags
