Other Google search not working
Discussion in 'Software' started by CrapBag, 21 Sep 2014.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Google.co.uk search isn't working on my pc and my laptop anymore and the rest of the family are also getting intermittent usage.
    Anyone got any ideas why?
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    has someone inadvertently changed default search engine on your browsers?
    or do you have an issue with a compromised router? check those first if you haven't already
    another thing to try is a tracert to see if there are some problems with your isp
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I don't think anyone has changed anything and they would have had to have done it on all 6 pc's in the house as they are all doing it.
    How would I check if my router had been comprimised?
  4. RichCreedy
    24 Apr 2009
    which router is it?
    check the dns settings that's what normally gets changed, so that you are routed through a dodgy server
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    DNS looks normal it's all set to auto so no info has been put in that I can see.
  6. RichCreedy
    24 Apr 2009
    open cmd prompt and do a tracert google.co.uk and tracert search.google.com
