Development Google Sites & Jscript help
Discussion in 'Software' started by Burnout21, 20 Jun 2016.
  1. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Hi,
    So I'm trying to embed a simple little bit of code to a "google sites" site for work, and I have been out of my depth since the beginning. (It's a personal work project to try and help others eventually.)
    Anyway I have been pulling my hair out over this all weekend.
    Code:
    <!DOCTYPE html>
    <html>
      <head>
        <base target="_top">
      </head>
      <body>
    <input type="text" id="Honeycomb" >
    <input type="text" id="Skin" >
     <p>Click the "Calculate" button to get the Honeycomb Thickness.</p>
    <button onclick="myFunction()">Calculate</button>
     <p id="HC"></p>
     <script type="text/javascript">
    function myFunction() {
        var a = document.getElementById("Honeycomb").value;
     var b = document.getElementById("Skin").value;
        document.getElementById("HC").innerHTML = a-b;
    </script>
     </body>
    </html>
    It works perfectly fine over on w3, but when loaded into the "sites" site, it fails to function.
    Then I read how google has prevented <scripts> from starting, so I went the route of a HTML box hoping that would change. Nope.
    Then I tried the Google Scripts, and link, but still nope.
    Where am I going wrong?
    I have grand plans if only I could overcome this small irritable stumbling block.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    You could do it via apps script (basically same as javascript) and embed that in your site - basically just publish your webpage as a service and embed it.
    have some demos i can share the sites link for, but it's semi work specific so would rather not publish on the wider interwebs (and some other cool email based demos)
    It's relatively straightforward to do (google apps script is fricking awesome too) and may get you what you want...
    Otherwise a friend recommended AWS for basic hosting - you have to configure the server yourself bu he pays next to nothing per month for the light use his site gets + you could do whatever you wanted.
    <edit>
    Ok, had a shot at this - pretty much just copy/paste your code and add some basic gs to point it to the html file - if you have a google account i'll send over the project.
    This link should work for anyone and can be embedded in a sites page easily enough or run standalone
    https://script.google.com/macros/s/AKfycbweq4pKYSnpkvPiE6Y0mXYa7m74B75uJWajoAQxJR_fb1Uz-il_/exec
    </edit>
  3. Burnout21
    9 Sep 2005
    I tried the app's script, but it fails to load it. Could it be because I have html inside the script?
    Webdev or any dev to that matter is very much my weakest area.
  4. Highland3r
    25 Jul 2003
    See edit above. If you have a gmail account, shoot me a PM and I'll share some code with you. Can talk you though a though things as well if needed - I'm no web dev either but apps script is pretty awesomesauce!
    Burnout21 likes this.
  5. Burnout21
    9 Sep 2005
    PM'd
