Windows Googlebar not working in IE 11
Discussion in 'Tech Support' started by nichos, 24 Mar 2015.
  1. nichos
    nichos Minimodder
    17 Feb 2006
    Hi,
    Google bar in IE 11 (w8.1) is enabled but does not show up, instead I get an X on left hand side.
    Anybody knows how to get it to work?
    __________________
    Asus P5K Premium WiFiiFi, Intel Core 2 Quad Pro 2.4GHz, OCZ Cpu Cooler, 2x2GB, DDR2 800 PC2-6400, GeForce 9800 GTX (PCI-E), sata 160gb, OCZ 600W Psu, XP/Win8.1
  2. Qazax
    Qazax Fap fap fap
    20 Aug 2012
    Firstly why are you using IE? It is possibly the worst browser out there. Secondly if you really insist on using IE, try setting google as the search provider - then you can just search directly from the address bar in IE.
  3. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx, I'll try that
  4. Atomic
    Atomic Gerwaff
    6 May 2002
  5. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    toolbars are evil and should never be installed, do as the others have suggested and set google as default search engine.
    if you really must use the google toolbar uninstall it, then reinstall, its usually a bad update that breaks the toolbar, either that or the toolbar is an older version that need updating
  6. nichos
    nichos Minimodder
    17 Feb 2006
    Thanx,
    OK now it showed up.
