Modding Got a global win case but...........
Discussion in 'Modding' started by couzo, 10 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    In the instruction (which are pretty pants!!) there is a small bit of paper that shows where to put 4 screws and the rubber bit. What is this for?
  2. couzo
    26 Apr 2002
    also has anyone got an electric shock off these cases by touching the frame when the side is off?
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    did you get one? if you did you might have put an extra standoff under the mobo and it is making the case live.
  4. couzo
    26 Apr 2002
    sorry what does that mean?
  5. Adam
    Adam Minimodder
    26 Jan 2002
    The brass screws under the motherboard, if there is an extra one without a corresponding hole in the motherboard it might be connecting the motherboard to the metal of the case, causing it to become electrically charged. I think I explained that properly. Also is it earthed properly?
