Cooling Got a watercooling question
Discussion in 'Hardware' started by RR5, 9 May 2004.
  1. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    If my room temps are pretty warm during the summer season, would it really make sense to try watercooling to lower cpu temps and perhaps overclock a bit?
  2. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    yes. as long as ur room temps dont exceed the curent temp of ur chip(which they shouldent unless u live in hell or mexico) unrealted why isnt the a frosty smilie anymore
  3. RR5
    7 Dec 2003
    Yeah thats what I thought, watercooling might even help lower the room temp.
    If you click more you'll see :brrr:
  4. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    ugh? Interesting :eyebrow: My computer runs between 7°C and 12°C hotter then the ambent temperature for my room, in summer the temperature of my room will hit around 27°C so that makes a CPU temp of around 34°C to 39°C depends on how much hotter your room gets tbh.
    As for making your room cooler, not gonna happen, the heat you CPU makes needs the be disperesed into the suroundings, a W/C setup does this more efficiently, therefore it will make the room hotter if anything, but it should stay the same.
    'doc
  5. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    It won't make the room hotter. It simply won't make a difference. The same amount of thermal energy will be dissipated into the air.
    8-ball
  6. SlackeR
    SlackeR What's a Dremel?
    17 Mar 2004
    hehe only if he's a ***** :D
    he should clock it further on water :naughty:
  7. Murdoc
    25 Jul 2003
    8-BALL is only saying it wont make his room cooler, as for clocking it depends what his chip will give him stable on air and water.
    'doc
  8. 8-BALL
    6 Nov 2001
    What I'm saying is that the cooling system (provided it is not an active heat pump ie pelt or HVAC) has no effect on the ambient temp, only the difference between the ambient temp and the cooled component. The heat load from the processor is the same regardless of cooling method, unless you overclock it.
    8-ball
  9. RR5
    7 Dec 2003
    All right, now what about watercooling a power supply?
  10. Murdoc
    25 Jul 2003
    not a task for a watercooling noob and :search: their are pleanty of threads out their detailing what needs to be done.
    'doc
  11. SlackeR
    17 Mar 2004
    and i am replying to what he said: "It simply won't make a difference" ;)
  12. Murdoc
    25 Jul 2003
    I sort of get ya meaning now...i think
    'doc
  13. wharrad
    wharrad Minimodder
    26 Jul 2003
    You could buy a ready made water cooled PSU - they're expensive and usually need to import them from Germany - although wizard designs in Wales does that sort of thing (Pug). Have a look in the products section.
