Case Mod - In Progress ⭐ GOT Mod
Discussion in 'Project Logs' started by Pennywise, 30 Jan 2018.
  1. Pennywise
    Pennywise Member
    6 Nov 2011
    Its that time again.
    This build will be themed after the iconic tv series Game of Thrones.
    Using a Corsair Air 240, I will be building out the case to look like a castle.
    Then with a combination of 3d printing and sculpting, I will be building out a dragon perched onto of the case.
    Not sure on the game of thrones badging. I'm sure by the time I get most of the sculpting done, I will have figured it out.
    Huge Thanks to my sponsors for this build.
    Nvidia Geforce Garage - Corsair - MainFrame Customs
    I will be posting pictures as the hardware rolls in.
    Dietec likes this.
  2. Pennywise
    Pennywise Member
    6 Nov 2011
    This build started out with a Corsair Air 240 case.
    I glued some 1/8" polystyrene together to make a base layer to the castle.
    This will give me something to build off of.
    I figured this build is going to take quite a bit of Magic Sculpt, so I picked up 20 pounds.
    While I sulpted the side panels, my 3d printer was printing out the base form for the dragon.
    I had to print it out in pieces and glue it together.
  3. Pennywise
    Pennywise Member
    6 Nov 2011
    I received the first of the packages this week from Nvidia and Corsair.
    There will be more to come from Corsair and Mainframe Customs.
    Nvidia sent me 2 GTX 1080's, HB Bridge, EVGA X99 Micro 2 motherboard, and a Intel I7 5930K CPU.
    The first of a few other packages came in from Corsair.
    The Dominator Platinum Special Edition Torque 32GB 4x8GB DDR4 Ram.
    I made some pretty good progress sculpting this week.
    The castle stone work is complete and the dragon is all glued together.
    All the seams and flaws are filled in the additional sculpting is complete on the dragon.
    I applied the first coat of primer filler to identify the flaws and areas that need more work.
    It needed some lighting on the front, so I sculpted some torches out of flicker LEDs.
    I also started on the distressing of the castle.
    There is quiet a bit more to do, but its a good start.
    Finished up the night, by applying a couple more coats of primer filler.
    Here is a video of the torches I added to either side of the gate.
  4. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    Got an old skool mod feel about it , loving the skill you bring to this mod, pitty we just dont get to see any of them being done. how'd you make the torches?
  5. Pennywise
    Pennywise Member
    6 Nov 2011
    Defyant, I wish I had more time to walk through each step.
    For the torches, i took a pre-wired flicker LED. ran the wire through a short acrylic tube.
    I then bent the wire, so it is 90 degrees out from the tube.
    Using magic sculpt, i sculpted the torch directly onto the wire.
    I then used a hot glue gun to make the flame around the LED.
    I'm trying to get as many updates as I can.
    I've been working 60 hour work weeks at work, so I don't have much time at the end of my days to mod.
    Using a Dremel grinding tool, I have been working on distressing the case.
    The windows and openings needed to look like it has been broken out.
    I have also started working on the Game of Thrones logo.
    Using my 3d printer, I made some lettering and sprayed it with primer filler to get rid of the gaps.
    The background for the lettering will be sculpted to look like a broken wood plank.
    After trying out different areas, I decided to attach the logo to the front of the case.
    I will be using stand offs, so it is floating slightly off the case.
    There is also a video link at the bottom.
    Here is a video of the status of the mod.
  6. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Hey Pennywise, your sculptures always look amazing. I was wondering if you are also allowed to give the inside of the mod / the hardware etc a GOT feel to it.
  7. Pennywise
    Pennywise Member
    6 Nov 2011
    Yes I will be highlighting certain areas inside the build to the match the theme of the case.
    I am getting some of the hardware pretty close to the finish date, so not sure how much modding will be done on those parts.
    There were a couple ideas i had to scrap because of time restraints.
  8. Pennywise
    Pennywise Member
    6 Nov 2011
    I finished up most of the GOT logo tonight.
    I'm going to call it a night and get some extra sleep tonight.
    There is still a little more to add, and I need to attach the stand off's.
    I sculpted out most of the wood plank and attached the lettering.
  9. Pennywise
    Pennywise Member
    6 Nov 2011
    I finished up the logo, drilled some mounting holes in the front.
    I used some fender washers and welded some 1/4" nuts to them.
    Then, I used construction adhesive and attached them to the plastic on the back.
    I sculpted the rest of the plank, over the top of the washers.
    All I have left is to cutsome acrylic tubes to cover the threads of the 1/4" bolts.
    Also, being able to remove the logo will make it much easier to paint everything.
  10. Pennywise
    Pennywise Member
    6 Nov 2011
    I received another killer package from Corsair.
    The Commander Pro, RGB LED lighting kit, (x6) LL120 fans, and a Corsair H100i v2.
    I decided to switch gears and work on my backplate cover.
    The second picture is of what I am aiming for.
    I started out by covering the backplate with transfer tape.
    Then I started by drawing the image onto it and cutting out portions of the image to sculpt.
    Can't wait to see this one all painted up. It tured out pretty sweet.
  11. Defyant Mods
    14 Sep 2004
    ^^^ Damm that's sexy!:thumb::thumb::thumb:
  12. Pennywise
    Pennywise Member
    6 Nov 2011
    Sorry, not many post right now guys.
    I have to have this finished by thursday.
    I'll post some pictures from PDXLan in the first Nvidia Mod contest this weekend.
  13. Sn00k3r
    Sn00k3r Member
    7 Apr 2011
    doesn't it have to be named Throne of Games...? :eyebrow:
    Great work, keep going! :grin:
  14. Dietec
    Dietec Active Member
    2 Oct 2017
    I really like that backplate.
