Cases Got my Define r3!
Discussion in 'Hardware' started by Syn, 4 Sep 2010.
  1. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    Just got my Fractal Deisgn define R3 case straight from sweden!:D I've got it before any of the UK stores even have them in stock.
    Going to post some pictures and thoughts in the thread as soon as I find batteries for my camera
    Also any questions, I'll be happy to answer.:thumb:
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    Sweet, what color?
  3. murraynt
    murraynt Modder
    6 Jun 2009
    Review:thumb:
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Pictures!
  5. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    Looks pretty sweet on the outside, pretty much the same as the r2 though. Aparently the paint has better scratch resistance, but I can't really compare it. As you can see I got the Black Pearl one.
  6. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Is the sound proofing material still the smelly bitumen stuff?
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    That picture is way too small.
  8. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    I haven't seen the bitumen stuff, but my brother came round (he has an r2) and he said its a completely different material.
    Heres the stuff, with my old Coolermaster fan. And no it doesn't really smell, give it a good sniff and it smells like a new pair of shoes :thumb:
  9. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    +1, I can barely see it. :D :duh:
  10. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    Here are the delicous guts! Made quite a tidy job of it, I have yet to sleeve my cables, but I plan to do so with white sleeving. And yes I know my Optical Drive isn't plugged in ;)
    Also, do you guys want me to resize the images, or is it alright?
  11. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Please resize, anything over 1000px wide isn't really necessary. Or at least compress the images a bit, raw images from the camera are always huge files.
  12. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Looks awesome! Can't wait for these to be available. Scan has already gone end of line on the R2.
  13. Matticus
    Matticus ...
    23 Feb 2008
    I might have to pick one of these up. I have a bunch of silent eagles to go in it. What do you think would be the best set up, another front intake, one exhaust on top and either side or bottom intake for the graphics card?
    How is the general build qaulity, like the fitting of the side panels etc?
  14. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    Build quality is good, it feels very solid, and has a lot of weight, which adds to the good feel.
    However with both side panels, it takes quite a lot of force to get them off.
  15. Matticus
    Matticus ...
    23 Feb 2008
    I don't mind if they require a lot of force, just that they line up correctly. I have had a few cases where the panel is noticeably off either to the edges of the case or from the holes at the back. I guess I need to start buying Lian Li's :p
    I am seriously considering this case, I will wait for a few reviews. Not because I don't believe what you are saying, but just that you may have got lucky and got a good one. I heard that the R2 had some quality control issues, but some people got 100% perfect cases, others got dogs so it was very inconsistent.
  16. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    They line up perfectly, sometimes when you remove one one or two of the latches stay hooked, and you have to wiggle it lose. But when its on its a solid fit, and looks perfect.
  17. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Looks the same as the R2 tbh.
