Modding Got My Dremel Today!
Discussion in 'Modding' started by Visualaid, 1 Dec 2003.
  1. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    Hey guys
    I got a dremel of ebay the other week and it arrived today cant wait to do a mod with it i probablly going to try etching something first in acrylic :D.
    I was just wondering though when the dremel is on theres a motor kind of smell. I cant explain it just a smell of a motor type of burning not sure if this is bad or good :).
    I'll post some pics later and i didnt realise how small a dremel actually is!!!.
    VisualAid-
  2. Visualaid
    15 Apr 2003
    anyone know about the smell yet?
  3. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    30,000 RPM of Modding power at your fingertips!
    Usualy the dremel needs to break in the brushes, bearings, wiring and the likes, Kind of like a new car... Be sure to check your voltages and that you are running a 110v on 110v or a 220v on 220v. :rock:
    Aside from that... Ain't they just glorious little buggers!!!! :hip: :dremel:
  4. Bossman
    Bossman What's a Dremel?
    6 Nov 2003
    Take care when dremeling acrylic as it can be a right bugger to work with. It can melt at the drop of a hat. And i wouldnt try sanding it with a sanding drum either.
  5. Visualaid
    15 Apr 2003
    melts if you dont use yer noggin speed 1 and 2 for acrylic maybe 3 for high speed buffing :).
    i got the hang of it already :D.
    i love engraving coca cola logos!.
