Graphics Got My X800GTO!!! W00T!!!
Discussion in 'Hardware' started by dave2k2005, 10 Oct 2005.
  1. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Nice, I plan to get one of these babies too :D preffablely the connect 3D, Also Im sure you can flash these to the X850 Xt -PE's Bios :rock:.
    Also this guy does some crazy volt/cooling mods. "make your card look like a fire engine" :lol:
    -Fr4nk
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    Those cards are pretty damn good value for money, that score is only ~2000 off my GTX. It'd be even closer when unlocked (only the Sapphire ones unlock IIRC).
  3. Fr4nk
    12 Mar 2005
    I beg to differ :hip:
    fr4nk
  4. allforcarrie
    allforcarrie Banned
    22 Jul 2005
    :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
  5. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    Crazy guy! I can definately do better, but theres no way I'm sticking a pelt on it and going that extreme. Under water and voltmodded I might hit 650/625 or so, but who knows. Need to experiment a bit and see if can water cool the card's RAM without too much restriction... Will try the Omega drivers as well.
    But value-wise this card cant be beat. Paid under $350 for that Opteron and x800GTO combined...
  6. Fr4nk
    12 Mar 2005
    just jioned the connect3d x800gto club, all pipes unlocked @ 16p, 540Mhz core, 560Mhz mem. 40c Idle, 73C is the highest its gone so far. Currently artifact checking, downloading 3dmark 05, will post results later.
    -Fr4nk
  7. jamadaia
    jamadaia What's a Dremel?
    18 Jan 2004
    How much did the connect3d cards set you all back ?
    Just trying to compare this for value against the x80xxl (which is already 16 pipes) and even the 6800GT etc.
    I think my 6800gt used to give about 6k anyhow. And they can be had for near 150.
    What you guys think?
  8. Fr4nk
    12 Mar 2005
    I got mine for £138 from www.overclockers.co.uk :thumb:
  9. zhenboy
    zhenboy What's a Dremel?
    23 Dec 2003
    Whats the different between GTO n GTO2?
  10. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    A GTO2 is 99% garuanteed to unlock with out any problems. With a standard GTO it either might not unlock or the pipelines could be damaged leading to artifacts.
  11. Fr4nk
    12 Mar 2005
    also the gto2 has the R480 core making it a better overclocker :thumb:
  12. otm3x
    otm3x What's a Dremel?
    28 Oct 2005
    Where did you guys get the Vmod information... ??
    thanks
  13. Adnuo
    Adnuo Banned
    28 Aug 2005
    ...This makes no sense. I get around 5533 with my 6800GT at 415/1080 in '05. Either the X800GTO is officially the new value for money card for the next two months, or I'm smelling some BS...
  14. Fr4nk
    12 Mar 2005
    lol check this then,
    My best score ever on my x800gto, clocks are in the sig :thumb:
    I got my Info from techpowerup on the voltmod for x800/non-pro cards but the board layout is quite differant so i emailed Viper John and he showed me what to do :thumb:
  15. user0001
    8 Sep 2004
    No BS here - that was running at the clocks noted and with an Opteron (San Diego) overclocked past FX-57 speeds. I'm hoping to pass 7k soon (finals week ATM) after putting it on water and possible doing a slight volt mod. They are excellent cards, but I've been seeing 7800GTs for $280 or so, which also are a good option.
