Graphics GPU confusion - anyone help me choose? £150 budget
Discussion in 'Hardware' started by SpyderBombz, 2 May 2016.
  1. SpyderBombz
    SpyderBombz Member
    21 Jan 2013
    Hi all
    I've been away from these lovely forums (and out of the PC loop) for about 3 years. I had planned to build back then but various things got in the way and it never happened.
    Now I'm in the position to actually get a system built and I'm pretty set on most of the parts but the only thing I'm clueless about is the GPU choice.
    I have a max of £150 to spend but I have no idea what to go for. I'll not be gaming at any higher than 1080 for the foreseeable future but I still want decent performance and at least some sense of future proofing. I'm hoping for a better experience than my Xbox one. I'll also be rendering short videos (HD not 4k)
    So I throw myself on the mercy of the knowledgeable people here.
    What's the best bang for the buck GPU that £150 will get me?
    Thanks in advance!
  2. Greentrident
    Greentrident Active Member
    10 Jul 2009
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  4. ripmax
    ripmax Active Member
    8 Apr 2010
  5. SpyderBombz
    SpyderBombz Member
    21 Jan 2013
    Thanks for the replies.
    Is a 2GB card enough these days? Should I try to up my budget to £175 to try to get a better 4GB one?
  6. Lukart
    Lukart New Member
    25 Apr 2016
    Same opinion here. Go for the 380, you cant go wrong.
    Specially now that AMD got his stuff together and their drivers are performing better than nvidia. :clap:
  7. spolsh
    spolsh Active Member
    4 Feb 2012
    I'd say it'd be worth it. 2GB is starting to be limiting from what I read on various forums.
  8. TheMadDutchDude
    23 Aug 2013
    I'd definitely up it to go for a 4GB card without a doubt. 2GB is a little too low by today's standards.
  9. Isitari
    Isitari Active Member
    6 May 2009
    Or get a GPU second hand off somewhere like here :).
    I found 2GB of video memory starting to limit some of my games at 1080 and upgraded to 4GB (an Asus r290x DCU II I bought on here for less than £200).
    Sent from my SM-N915FY using Tapatalk
  10. SpyderBombz
    SpyderBombz Member
    21 Jan 2013
    Is there anything I should be wary of buying a S/H GPU?
    Sent from my Nexus 10 using Tapatalk
  11. Isitari
    6 May 2009
    I personally avoid eBay, but that might just be me because as a buyer you're far better protected than as a seller. To make everyone's life easier I just get my S/H stuff off here because I know people here are far less likely to rip you off or sell something duff and would be willing to help you out if something goes wrong :).
    Of the 3 GPU's I've bought off here all have worked perfectly and I've sold 3 GPU's with no issues at all as well.
  12. SpyderBombz
    SpyderBombz Member
    21 Jan 2013
    I can't seem to see any classifieds, is there a minimum post count or something similar to gain access?
  13. Isitari
    6 May 2009
    Ah yes. You need to have been a member for at least 3 months and have 150/175 posts (can't quite remember which). Sorry I didn't realise you were 'that' new ;).
  14. Guest-16
    Guest-16 Guest
    In about ~4 weeks will you see 2nd hand 970s go for that price I wonder?
  15. TheMadDutchDude
    23 Aug 2013
    They're already at £180 - £200 second hand. They will probably drop to the OPs budget, yeah! :)
  16. SpyderBombz
    SpyderBombz Member
    21 Jan 2013
    Is there something new on the horizon that means people will be upgrading? If so ,I'm ok with waiting a little to grab the leftovers!
  17. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Yes there are new cards coming from both AMD and nVidia, that are rumoured to be within the next 6 weeks potentially iirc.
    Personally I think the new cards will be released this month but will have to wait and see, but when they do come out there will be people upgrading to them so they are going to get rid of there old cards.
