Basically the topic question, looking at an nvidia card specifically. I have a 285 gtx currently but it's on it's way out. Looking to get something more powerful at least. Help please!
Ahh it would seem that Hardware king is throwing all the google pricing off, most 570's will be above your limit, if you can find a 448 core 560TI then go for it, otherwise a 2GB 560TI (384 core) should see you into the future.
Yeh, I think all/most 570's are above £200. A 560 ti 448 might actually be the best choice if going down the Nvidia route. 6950's could be purchased for under £200, so that would also be a good choice.
I'd go for a 570 if you can stretch to 240 or so, otherwise the 6950 is pretty good bang for the buck.
