Graphics GPU not found?
Discussion in 'Hardware' started by louist44, 26 Mar 2011.
  1. louist44
    louist44 New Member
    19 Jan 2011
    Just completed my first build. took 3 hours and i crapped myself all the way through.
    I installed windows 7, and decided to check what my system was rated just for fun, when the score came back it said that the GPU rating was 1.0. Does this mean my graphics card is not recognised (havent updated any drivers yet)
    Specs are
    i5 2500k
    8gb Corsair XMS 3
    750W Corsair PSU
    MSI GTX 560 Twin Frozer
    The Card is on, the fans are spinning. (not sure if it is supposed to have lights or what not)
  2. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    Download the latest graphic driver from Nvidia and re-run test.
  3. Omoobhs
    Omoobhs One giant fsb hole
    15 Nov 2010
    I would load the drivers for your gpu. More than likely the issue
  4. Siwini
    14 Sep 2010
    Believe me I been there you will keep getting 1.0 in WEI until you download the latest drivers. It only takes few minutes to do it..
  5. GoodBytes
    20 Jan 2007
    Your GPU is not recognized at the moment by Win7 (too new).
    Basically Windows Update probably failed to find your drivers. Go on Nvidia website, and get the latest drivers as Siwini and Boff_In said.
    Once you do and installed it, restart your computer and your should be ready.
    You should also have Aero enabled by that point, or be able to enable it (transparency on your windows, and task bar).
  6. Omoobhs
    15 Nov 2010
    I hope that it is a driver issue and you can relax about the build ;)
  7. CrazyJoe
    CrazyJoe Well-Known Member
    4 Aug 2010
    Windows update found the drivers for my MSI 560 Twin Frozr.
    Get your update on!
    I got 7.9 for my gaming graphics after the drivers were installed, it made me happy.
  8. louist44
    louist44 New Member
    19 Jan 2011
    hahahah oh my. There was me thinking I killed it with static.
    :D:D:thumb: Cheers all !
