Graphics GPU upgrade £180-200ish for BF4
Discussion in 'Hardware' started by aLtikal, 1 Mar 2015.
  1. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Hey. I Need an upgrade and I've been looking at GTX 770, 280X and GTX 960.
    Not really sure what to go for tbh.
    I was thinking of going for a 770 but the availability is low as the 900 range has been released, and there's a few issues with these?
    Are there any other cards due to be released soon that might be worth considering?
    BF4 performance is paramount as its pretty much the only game I play.
    Any pointers much appreciated. :thumb:
    Allan
  2. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    i have a 280x, i can max the game with no frame drops at 1200p no problem with or without mantle.
    Your CPU may struggle tho
  3. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    960 for cool and quiet running.
    280X for absolute max frame rate in BF4 specifically.
    But overall a 960, only slightly slower but much less heat and noise to shift.
  4. TheMadDutchDude
    23 Aug 2013
    At your resolution, your CPU is going to hold you back. You need to be at 1080P or greater for the CPU bottleneck to shift to a GPU bottleneck.
    I'd personally go for a second hand card. You can pick up a 7950 for £100 and they're monster cards. You should also increase the overclock on your CPU. There's no reason it can't push 3.6 GHz, unless it's a B3 chip.
  5. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    I'd go for a 280/280X, 2gb on a video card is going to give you issues in certain games.
    Not forgetting that a 280X gives you access to Mantle in Battlefield 4 which is going to give you an improved gaming experience over DirectX. :)
  6. mrbungle
    20 Sep 2004
    For £200 cant you get a 290?
    I know it will be bottlenecked by a Q6600 currently but it is such a better card over a 280X which is just a 7970 rebadged.
  7. aLtikal
    7 May 2008
    Cpu will be upgraded soon :) very good pointers so far. I think I'm leaning on the 280x but might be getting a mini ITX case for my next upgrade so if I do this ill go for a 960. Thanks everyone.
  8. loftie
    loftie Multimodder
    14 Feb 2009
    Shame you didn't want one a couple of weeks back, there was the PCS 290 on overclockers for £199.
  9. stealth80
    stealth80 Minimodder
    1 Feb 2015
  10. davidbrown1988
    davidbrown1988 Minimodder
    8 Mar 2008
    I bought my 770 while I still had my q6600 in my main rig and it massively bottlenecked the card, upgrading my processor almost doubled the performance I got out of it.
    At your slightly lower res you might notice some more gain but you are always going to be limited by that CPU.
    As you've said you'll struggle to find a 770 anymore. The 280x is only slightly slower but gives you the extra 1GB vram which some games are already making use off.
    Otherwise as already said stretch for the 290.
  11. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    Davvy is selling a 290 in the mm
  12. dhicks001
    dhicks001 What's a Dremel?
    7 May 2011
    If it was my money I'd get a 960 with the mindset of potentially getting a second one for SLi in the future.~
    But best bang for buck card at the moment is definitely the 290.
  13. aLtikal
    7 May 2008
    Ahhh damn you guys my budget is now creeping towards a 290 lol. It all depends if i want a laptop, ITX or standard PC.... Cant decide :/
  14. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    it's £160 :)
  15. loftie
    loftie Multimodder
    14 Feb 2009
  16. TheMadDutchDude
    23 Aug 2013
    I'd rather flush my money down the toilet than buy XFX. It's well worth spending a little more to get a decent brand.
  17. alfizzle
    alfizzle Ooh aah just a little bit..
    3 Apr 2013
    TLDR;
    There is a 290 in the marketplace for £160, that's a solid card for bf4 :)
  18. stealth80
    1 Feb 2015
    that's tempting even for me with a 970gtx lol, wouldn't mind 2x in CX fire
  19. Otis1337
    28 Nov 2007
    If its reference PCB it dont make a difference.
