Cooling GPU waterblock?
Discussion in 'Hardware' started by H4wk1e, 10 Dec 2006.
  1. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    I have a nVidia 7800GT (SLi) XFX GPU
    Was wondering with the following two that will fit it,
    Is it worth extra money to go with the "Danger Den NV-78 (Rev1) Water Block" so that it cools the Ram as well as the chip, will this make a difference?
    or stick with the "Danger Den Acetal Maze 5 Low Profile" for just the chip.
  2. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    Does anyone have and idea?? please help?
  3. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    I would stick with the Maze 5 since your not going to see any significant performance increase if any. So long as you put ram sinks on the memory you will be fine.
    You may be able to increase the memory clock going with the NV 78 block, but I'm sure the price vs performance ratio is not going to be great.
  4. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    im not really thinkking of overcloking the GPU so your prob right.
