News GPUs 'only' 14 times faster than CPUs
Discussion in 'Article Discussion' started by CardJoe, 25 Jun 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    What happens if you use a GTX480?
    Utter annihilation?
  3. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    The atmosphere catches on fire and the world ends :)
  4. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    Not particularly surprising tbh. Didn't expect the 14x boost over a CPU but it was always going to be a significant margin.
  5. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    More seriously, there doesn't appear to be any explanation of what specific tasks, applications, drivers and libraries were used to get these results - all of which will massively effect the result.
    i.e. pre mid-2009 a GTX 285 would easily outperform a Core i7 in Folding@home, but after that (with the release of new clients) the CPU would be faster.
    As always, it depends on what your doing with your hardware.
  6. mjb501
    mjb501 What's a Dremel?
    20 Jun 2010
    The results seem to tie in with the preformance gains I have seen doing GPGPU at uni, yes the GPU is a lot faster at certain tasks but there are others such as branching where the performace gain is significantly less plus the fact that existing software would have to be recoded for x86 to CUDA/OpenCL.
    I'd like to see a comparision of performance per watt of the CPU and GPU running these tasks.
  7. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    Does that mean that Intel just owned themselves?
  8. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    Does this imply that there are lessons to be learned from gpgpu's for cpu manufacturers? Is it possible to apply knowledge from one field to the other and narow the gap? AMD would be in a great position to do this.
  9. memeroot
    memeroot aged and experianced
    31 Oct 2009
    @Lizard - I thought the new clients were a little bit dishonest regarding cpu/gpu performance
    @mjb501 - performance per watt would be interesting but I think we can guess given that you'd need a <5* performance improvement to make it worth while
    @rickysio - you'd have to hope so given thats what the 480 was designed for... heck it's faster than a 5870 which was 'just' designed for graphics.
  10. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    In what way? Do you mean how the apparent performance (if you're measuring in ppd) of the clients has varied over time as Stanford adjusts the points system?
  11. Shagbag
    Shagbag All glory to the Hypnotoad!
    9 Nov 2006
    I'm amazed Intel fessed up to it in the first place.
    Marketing wise, they've shot themselves in the foot with both barrels.
    I have absolutely no doubt that they loaded each test with as much bias as possible.
    The fact that they used a GPU that was 1 year older that their CPU is proof in point.
    To then come out and say the GPU was at least 2.5 times a fast as their CPU (at parallel processing tasks) is amazing.
    One thing is for sure: no way in Hell would Apple's Marketing Dept allow such a test result to be released.
  12. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Quite so. Actually, I'm surprised it's only 14 times; for graphics I suspect it would really be quite a lot more than that, frame rate for frame rate (though a CPU based graphics engine would likely give more accurate results, if you care).
    P
  13. rickysio
    6 Jun 2009
    It's not really marketing - it's a paper for discussion by experts.
  14. memeroot
    31 Oct 2009
    @Lizard
    yep thats what I meant - though I only picked up the info from the forum - so I dont honestly know if it is true.
  15. Centy-face
    Centy-face Caw?
    26 Apr 2009
    Why do I get an image of Charlton Heston screaming on a beach looking up at a huge 480
  16. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    Employee: Doc, I've just pwned myself
    Prof: so what, you're a nerd anyway
  17. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Not surprised really. Only surprised Intel has let this information out.
  18. delriogw
    delriogw What's a Dremel?
    1 Aug 2007
    credit to them for not trying to hide it to be honest.
    they can learn from this as can the industry in general, it also shows the difference isn't as large as a lot of people thought, which in intels eyes is of course a positive (and so it should be).
    @ shagbag : the fact that apple wouldn't release this says more about apple than it does about intel
  19. wyx087
    15 Aug 2007
    expected result for a 3.2GHz i7 vs gtx280, in fact, 2.5x is about the speed difference i get when encoding a video on i7 860 and gtx260.
    what Intel should have showed is single threaded performance, or heavily branching based performance.
  20. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    I tried putting a Nvidia GeForce GTX 280 in my CPU socket but it didn't work. Can anyone help me?
    dark_avenger likes this.
Tags: Add Tags
