Windows Grand Theft Auto V
Discussion in 'Gaming' started by Quuwahi, 30 Oct 2012.
  1. Trance
    Trance Two steps forward, one step back
    6 May 2009
    Egh why didn't past me spend that extra £30 and get a 4GB card, damn myself!
  2. samkiller42
    25 Apr 2006
    Been playing on and off for most of the day. 2 Crashes on a single mission, 1st SP heist, Just as it's switching from Franklin on the bike to Michael in the truck.
    Sam
  3. MrDomRocks
    MrDomRocks Well-Known Member
    5 Sep 2011
    After a rocky start, an hour to unpack the game and then a bug/crash at the beginning. Known bug if you run the benchmark before completing the first two missions.
    After that smooth sailing, not running maxed out due to 3gb Vram constraints but still playing smooth as butter.
  4. rainbowbridge
    rainbowbridge Well-Known Member
    26 Apr 2009
    wow, the promised land is here!
  5. samkiller42
    25 Apr 2006
    Lowered my graphics settings to Nvidia Optimized, loaded up again, still crashes at the same point. Oh dear.
    Sam
  6. rollo
    rollo Well-Known Member
    16 May 2008
    Lack of latest drivers perhaps
  7. samkiller42
    25 Apr 2006
    That's using the latest drivers from Nvidia (350.12) So, Not entirely sure what's wrong.
    Sam
  8. rainbowbridge
    26 Apr 2009
  9. samkiller42
    25 Apr 2006
    Yep, those drivers indeed. I've just done it again, controller disconnected, and it crashed soon as i right clicked the mouse to start shooting, despite it being fine before then, So, not entirely sure what it's doing it.
    Sam
  10. rainbowbridge
    26 Apr 2009
    stop every thing else running in the task bar.
    run the game with keyboard and mouse only.
    reinstall the gpu drivers with clean install.
    check the steam forums
    https://steamcommunity.com/app/271590/discussions/
    disconnect any un-necessary hard, like joy sticks and stuff.. bring your machine back to basics.
  11. theshadow2001
    3 May 2012
    That's awesome. The only thing that comes to mind is:
  12. DragunovHUN
    DragunovHUN Well-Known Member
    30 Oct 2008
    This launched so smoothly it actually makes me feel uncomfortable. Something so pretty has no right to run this smoothly, it's just not how videogames work. And aside from having to figure out that Dxtory was causing crashes for me I've actually been playing ONLINE with no issues?!
    I will never be able to look at other games the same way again.
  13. wyx087
    15 Aug 2007
    I've had zero problems. It preloaded at max speed, it updated quickly and it ran beautifully. With all the pre-ordering cash :D
    One minor annoyance though, how to always run without always having to hold down Shift?
    (#firstworldproblems)
  14. lancer778544
    lancer778544 Well-Known Member
    5 Jan 2011
    Runs absolutely fantastic for me too. 45-60 (V-Sync on) fps for me with the GeForce optimised settings which are mostly high or very high. What's really good is it's taking advantage of all 8 cores of my CPU.
    Performance aside, really enjoying so far. I've put 4 hours in and I'm ~13% complete according to my save.
    Edit: Oh, and ~5GB of 8GB VRAM being used at 1080p.
  15. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Only thing I've encountered is if I exit the game gracefully it locks my PC up. Full on reset button action needed to bring it back.
    If I save, alt-tab and end process it's absolutely fine.
  16. Cei
    Cei pew pew pew
    22 Mar 2008
    I'm noticing a tiny tiny bug. When I complete (or fail) a mission, the key prompts for carrying on are cut off down the bottom right (so I can see the bit that tells me spacebar opens details, but not that enter is continue). Is this FOV related?
  17. liratheal
    20 Nov 2005
    There's a "Safe zone" or some such nonsense in one of the display/graphics menus - It moves stuff like that away from the edge of the screen. Found it completely by accident.
  18. Cei
    Cei pew pew pew
    22 Mar 2008
    Thanks :) I'll go find said option and shout at it. Stupid R*.
  19. TheStockBroker
    TheStockBroker Well-Known Member
    19 Nov 2009
    BUT, it only supports 16:9, which is annoying for us 21:9 "Super-wide" users, who'd like to move the HUD further out to the edges...
  20. Cei
    Cei pew pew pew
    22 Mar 2008
    That might be the issue, I'm on 16:10. I'll check later.
