Windows Grand Theft Auto V
Discussion in 'Gaming' started by Quuwahi, 30 Oct 2012.
  1. TheStockBroker
    TheStockBroker Well-Known Member
    19 Nov 2009
    Just came here to post that, no patch notes though.
    Mouse issues?
  2. Shirty
    18 Apr 1982
    I suspect the patch was to fix the user account name issue, which has obviously been causing outrage for a number of international users.
  3. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    250MB could be a bit big for the username issue?
    Unfortunately I'm reliant on Rockstar servers, currently 1.6kb dl speed
  4. samkiller42
    25 Apr 2006
    Yeah,
    So, The first SP heist, the Jewellery store, Escaping on the bikes, soon as i'm in the tunnel, if i left/right click the mouse or left/right bumper on the controller, the game crashes to desktop, And does it when i exit the tunnel and transfer to Michael who's in the truck.
    Mouse/Keyboard are plugged directly into the PC, Xbox One controller is plugged into a USB Hub on my display, but i do also plug it into the keyboard. Only other USB device i have always plugged in is a UareU Finger Print reader.
    Sam
  5. silk186
    silk186 Derp
    1 Dec 2014
    What is the general cause of loading times? Why do some games not benifit from SSD while others due. What is the bottleneck for loading times in GTA V?
  6. jinq-sea
    15 Oct 2012
    That's pretty seriously annoying - I'm sure you've probably had all manner of suggestions/ideas/tried all sorts, but is there any mouse driver/supportware installed?
  7. samkiller42
    25 Apr 2006
    I've got a Steelseries mouse, But the software hardly ever works, so, it's installed, but isn't running, I could unplug the UareU and see if that makes any difference.
    Sam
  8. TheStockBroker
    19 Nov 2009
    The fact it happens with controller as well as KB/M is weird though... Did you download it from steam? You should verify it's integrity to make sure it's not just a corrupt file problem.
  9. jinq-sea
    15 Oct 2012
    I'd verify the Steam files as TSB suggests, and if that fails, uninstall the Steelseries stuff, unplug the UareU, and try then. It's certainly annoying...!
  10. Mr Happy
    Mr Happy 4 8 15 16 23 42
    25 Apr 2009
    You can add your own music to GTA, nice touch
  11. rollo
    rollo Well-Known Member
    16 May 2008
    It's nice but there's a lot of people with issues reminds me of gta4 launch some people had the game working flawlessly others with the same system could not run it at all.
    Had a few issues myself on that heist mission that your on Sam. I verified the files and it re downloaded 2gb, the loading times between characters are because the world is streaming files if they are not ready then it takes longer. Xbox 360 used to suffer similar things after a few hours of playtime.
  12. Cei
    Cei pew pew pew
    22 Mar 2008
    Heist mission ran perfectly for me. Odd.
    My first step on troubleshooting would be to unplug everything apart from keyboard and mouse.
  13. samkiller42
    25 Apr 2006
    I have done, and i've un-installed the steel series engine, still crashed. On top of that, i've revalidated, and i've re-installed, so, not too sure what else.
    Sam
  14. Cei
    Cei pew pew pew
    22 Mar 2008
    Okay, silly suggestion, got another mouse to try?
  15. samkiller42
    25 Apr 2006
    It's crashing straight after i go back to Franklin on the bike, Worked perfectly when throwing the gas into the aircon, and worked perfect for Michael, shot the glass ok, soon as it went back to Franklin, i right clicked, and crash. Yes, i've got 2 mice i can try, so that's my next plan.
    Sam
    Edit: Just tried with a Microsoft Comfort Optical Mouse, Same crash, same place. Short of re-installing Windows and having literally nothing on the system.
  16. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Post update and now I'm getting a crash - From the start menu to loading the game, event ID 1000, task ID 100, Exception code 0xc0000005.
    Yay.
  17. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    I left my PC running over night to download the game (1.1 download speed) and had 6GB left when I turned it off before work.
    just restarted the download - 22GB left to download.
    Great, another 10 hrs
  18. Lankius Maximus
    Lankius Maximus Member
    21 Aug 2009
    I've been playing the game since Tuesday and must say I am impressed. Funnily enough though the largest amount of slow down I suffer is when I hit the outer less populated 'countryside' areas where my frame rates will slow from 55 - 60 FPs to around 30-35. This is only for a brief period but is still noticeable.
    It's installed on a crucial bx100 500gb drive with no hard drive and loads relatively quickly.
    I still have vsync enabled but I will try it without. There is definitely a high CPU load however I did try disabling the loader and it did crash after about 5 mins.
    Every thing is running at 1080p on very high. I will give an exact run down when I get time (3 or 4 days).
  19. oasked
    oasked Stuck in the Mud
    24 Aug 2005
    Finally got this through the post from Amazon. It's 7 DVD's! Awesome box as well, it must cost a fortune to print and distribute. Looks cool anyway and cheaper than Steam...
  20. MrDomRocks
    MrDomRocks Well-Known Member
    5 Sep 2011
    The most recent patch has caused my game to stop working without warning. I have had it happen about five times now. All during a mission I am trying to complete. The latest time was when I was driving. I have also had the game lock up when it auto switches between characters as per the mission.
