News Graphene transistor hits 300GHz
Discussion in 'Article Discussion' started by julieb, 2 Sep 2010.
  1. julieb
    julieb What's a Dremel?
    12 Aug 2010
  2. Andy Mc
    Andy Mc Modder
    23 May 2002
    It would be nice to see speed of 4ghz+ without any overclock needed.
  3. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    i think that it would be nice to have this but it would require a major overhaul of motherboards and the technology that transfers data becasue at the moment becasue of how fast optical drives and hardrives are, there wouldnt be much benerfit from this at this time and that is if you could find a motherboadr that would be compatable
  4. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Next time instead of GHz we'd be talking about how many THz your CPU is clocked at.
  5. adam_bagpuss
    24 Apr 2009
    OMG it sover 9000 THz !!!!!
    i haz uber pwnd u
  6. Plugs
    Plugs Minimodder
    5 Nov 2009
    these transistors are twice as fast as current silicon ones, and can (possibly) scale to another order of magnitude up
    which means approximately 10x - 20x faster than current CPU offerings
    30GHz-60GHz (stock)
    doesnt sound too shabby
  7. shanky887614
    13 May 2009
    i dont know about you, but i dont much care for the clock speed
    it is how efficent they are is what really counts
    for example a core i3 is more efficent and faster than the same speed core 2 duo
    thsi is the kind of thin i want not just more speed
  8. Mraedis
    Mraedis Minimodder
    5 Sep 2009
    I might be way off here, but I think it's a logical guess.
    If you replace every transister in mobo/cpu/ram etc, will they all operate faster, if they operate at all?
  9. BRAWL
    BRAWL Dead and buried.
    16 Aug 2010
    There be only one response for such an incredible speed boost...
    "BY THE EMPEROR IT SHALL BE SO!" I hereby demand that these things are used excessivly in future technology... of course said demands will fail, however... I can deal with a 60GHz CPU....
  10. mecblade
    mecblade 14 year old Technophile
    12 May 2010
    im quite interested in the response to this, from the companies like ARM and Intel though. If they manage to pull off a Graphene based CPU, they could have a massive advantage against the rest of their rivals. However, im sure Intel would manage with the amount of money theyve been spending last month. i wish they could spend 9 billion on good ol R and D :(
  11. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    as long as I dont need a 20,000 watt PSU to handle a 1THZ, that would be cool, honestly, even 1kw systems now are ridiculous,lol
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    That'll suck the socket out of your wall!
  13. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    I just got rid of my 64-core 46Ghz cpu, got quite old tbh. Planning to upgrade to the latest Intel 128-core 80Ghz plus a pair of Corsair DDR8 128GB ram. Though not sure wether it can run Crysis 2?
  14. Teq
    Teq What's a Dremel?
    11 Aug 2008
    I'm still waiting to release the kill bots, we need more power!
  15. borandi
    borandi What's a Dremel?
    27 Jan 2010
    Manipulating graphene is very tricky, compared to silicon. Bulk silicon, can be cut, etched, eroded, in a very regular way. Graphene, SWNT and MWNT can be a bitch, and don't offer the same categories of manipulation that silicon does. Thus the equipment to make a decent transistor array will need to be invented before graphene becomes the de facto material.
  16. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    just the leap in what you could do on the software end with that kind of speed.. huang needs to switch to graphene and then yell at everybody
  17. ChainsawBunny
    ChainsawBunny What's a Dremel?
    28 Jul 2009
    Finally something that can run Crysis at 60 FPS?
  18. Pete J
    Pete J Employed scum
    28 Sep 2009
    Hmm.
    What about the heat generated by one graphene transistor? Just because one can operate at 300GHz, it doesn't mean that a whole load put together will work at this frequency.
    *goes off to look at the thermal properties of graphene versus silicon*
  19. cgthomas
    20 Oct 2009
    That's right, but what about Crysis 2?
    I'm thinking about adding another 2 GTX 470 so I can have 3-way SLI. I would then be really happy if I can run everything on max at 23 - 36 FPS. I would be a happy man
  20. Pete J
    28 Sep 2009
    Well, the thermal conductivity of graphene seems to be quite amazing, so heat will be transferred far better out of a chip compared to silicon. I can't find any thermal expansion numbers though (though I've found it has a negative CTE between 30 and 300K).
Tags: Add Tags
