Graphics Graphical defects
Discussion in 'Tech Support' started by Darkwisdom, 5 Nov 2011.
  1. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Hello there Bit-tech.
    I have a problem with my graphics and hope you can help me.
    I have an old X1950XTX, i'm getting a GTX560ti for christmas anyway, but i just want to know the problem.
    I sometimes get artifacts when i boot the computer, it varies whether it happens or not. It happened before, but it stopped when i reinstalled drivers.
    I reinstalled the drivers again, it didn't work, i even used driver sweeper to make sure, when i reinstalled.
    Does this just sound like the card is buggered?
  2. MikeMK
    MikeMK What's a Dremel?
    24 May 2005
    Is it just when you turn on the PC (i.e. before you load into windows) or are they there all the time?
  3. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Did you OC it by any chance?
  4. Darkwisdom
    27 Aug 2011
    Sometimes it happens when the bios screen (AI lifestyle blah blah) comes up, and then continues into windows, sometimes it doesn't at all, it varies.
    And i haven't OC'd it. Someone told me these particular cards don't OC very well.
  5. Sterkenburg
    Sterkenburg To mod or not to mod...
    2 Oct 2005
    It sounds like it may be happening when there is a resolution change or when the card stops getting information then starts again, like when the screen goes black between the BIOS and Windows boots. If you change your resolution, can you make it happen?
