Modding Graphical LCD Order
Discussion in 'Modding' started by Visualaid, 6 Jan 2004.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    That's the one... :duh:
    I remember seeing the picture and reading the post. Been a bad day at work... :wallbash:
    I had a memory lapse....So we are all buggered then.. :jawdrop:
    I've striped my wires ready, but that about it so far....
  2. Fusen
    Fusen What's a Dremel?
    17 Jan 2004
    it surely cant be that hard?! a bunch of 20 guys gettin beat by a little lcd :duh:
  3. Henri
    Henri What's a Dremel?
    21 Jan 2003
    Be careful with the thing now if the pot might be damaged. Maybe better change a new pot. I once killed a Displaytech KS0108 display because of a bad pot.
    I think these are transmissive displays so you might not see it very well without backlight but in good light you should see something. I'll have to admit I have never tested this with CFAG12864-TMI-V so I can't say anything definitive. So you can remove the two backlight wires without affecting the rest of the display as the backlight pins just go to the backlight leds. But you need the potentiometer correctly connected to get the contrast working to see anything.
    You could try the test prog here: http://www.skippari.net/phpBB2/viewtopic.php?t=121
    Take the KS0108 version later from the thread, not the noritake vfd version from the first post.
    It doesn't use DLPortIO at all and everything is included in the package. It uses the WinIO port driver which is automatically loaded when you execute the program. There might be some problems with the automatic loading if you don't have admin rights.
    EDIT:
    I have also had problems with DLPortIO and sometimes it just refuses to load and I wasn't able to fix it. In newer programs I've used WinIO which is also faster and hasn't caused any problems for me yet.
    In that picture by Acrim the display looks like it would be close to working. Timing problems I think. What are the LPT settings in bios ?
  4. Arien
    Arien What's a Dremel?
    22 Jun 2003
    Acrim i need to order the kits for my LCD's asap, i'll speak to you on MSN later :).
  5. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Okay Henri, heres where i'm at now.
    Tried to run that software you linked to the animation thingy-bob, but it just ran then disapeared with no change to the lcd (was frozen on test screen) so i tried the old test program/liquid mp3 to see if i ould get anything, still nothing. So i felt the back of the unit, the chips like you mentioned, and the one furthest to the left (looking at it from the back) was very hot. I haven't changed anythign from last night when i took that picture, can you offer me anymore advice because i'm just about reasdy to give up, I've given hours to this and gone through alot of stress about it.
    I got my parallel port settings from the BIOS btw:
    378/IRQ7
    ECP+EPP Mode
    ECP DMA = 3
    Cheers!
  6. Henri
    21 Jan 2003
    Ok, hot chips never sound good. Are you getting picture at all anymore ? If not it doesn't sound good as if you got picture with the same config yesterday and there's no change then the controller chip might have burned. Does the chip always get hot even if you disconnect the display and then power up again ?
    Your parallel port settings should be fine but you can always test the other modes if you haven't already.
  7. acrimonious
    8 Nov 2002
    Even if i unplug then replug in it still gets hot, no config screen is displayed just a very hot chip and a blank (well an all-on) screen. :waah: :wallbash:
  8. Darkside
    Darkside What's a Dremel?
    16 Nov 2002
    I'm now getting a little worried about this...... mine is sitting here waiting for me to start the wiring, but I'm not sure I wanna jump into this just yet :worried:
    Darkside.
  9. acrimonious
    8 Nov 2002
    My advice for anyone would be:
    Make sure you PSU voltages are clean, there is no sources of interference anywhere near, there are no shorts at all, you don't give the board excessive heat when soldering and that the data wire is as short as you can do with. Oh also, the right wires in the right places really help alot :thumb:
    I have another display to try, but i think i'll leave it a few days, see how poeple get on, don't want to cook that too.
  10. Arien
    22 Jun 2003
    Ok my 5 just arrived, just need the wiring kits to come and i'll have a go :D.
  11. jay
    jay What's a Dremel?
    25 Nov 2003
    I would love to have a bash but NO kit yet
    hope someone gets it going because this will fit in my keyboard and I want it to work , just to show off at lan partys :D
  12. acrimonious
    8 Nov 2002
    It should have, i posted it at accy post office for gods sake! :worried:
    85 Worthsworth isn't it?
  13. jay
    25 Nov 2003
    85 wordsworth (checked original e-mail and this was sent)
    so are you local ?
    coz if you are we could sort out me pickin up or you drop off (will pay if other is lost in post)
    may be ZAPWIZARD could help coz he`s a bit smart with this kinda stuff
  14. crystalfontz
    crystalfontz What's a Dremel?
    9 Nov 2001
    Chris Amps asked me to check in here.
    What schematic are you using?
    LCDinfo only for software or are you also using PowerLCD?
  15. Darkside
    16 Nov 2002
  16. coorz
    coorz Miffed
    25 Apr 2003
    I have used this scheme to wire up mines, works 100%. Looks same as the one you guys use. Good luck.
  17. Cyberbob:-)
    16 Jun 2002
    Now for a really noob question.
    You know the Earth symbols. What actually do you have to connect those too?
    And also pin 20 on the lcd the one with th r7 resistor how is that bit wired up.
    R3 is the POT...right. So whats R7....Told ya noob questions... :blush:
  18. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    I think that the earth symbols means you wire it up to the ground (GND) black wire in the molex. I think im right but not 100% about it. As for the other questions im as lost as you are
  19. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    Which 1 of these god damn wiring displays works? theres been about 5 different ones. Some with pin 14 to 5v some with pin 14 to ground arg stupid!
  20. coorz
    coorz Miffed
    25 Apr 2003
    In both schemes on this page pin 14 goes to 5v(=+5volt). NOT ground.
    All earth connections should indeed go to the black wire of the molex.
    R7 is ALSO a POT (100ohm). It has three pins, the middle and either other one are shorted.
