hi all I have just been playing hitman absoultuion and I am seeing little black squares in game may be its a driver issue im not sure?. does anyone know of a fix for this please. I am currently using catalyst 13.3 beta. I really want to play this game but I cant play it like this its just annoying [/URL][/IMG]
1. Revert back to stock if overclocked. 2. It is a 'beta' driver, try the standard release. 3. Maybe try dialling back some settings.
my card is factory overclocked I havnt tweaked them any further so should be ok, maybe I will try some standard catalyst drivers. thanks
still no luck have tried standard catalyst drivers (13.1) and lowered in game settings to the lowest setting but im still getting the black squares not sure what to do? I don't think its my card as it is ok playing Battlefield 3
Can you, just for testing so that we can help determine the problem and find a proper solution, hopefully, (this is not to suggest it as a solution, of course not) can you downclock your card to normal frequencies of your card. In other words, remove the overclock done by the manufacture.
